s13gtr AWD S13
  1. Gday guys,
Here is my s13 i have been playing around with for the past few years, started out as a cheap drifta but got bitten by the drag racing bug and have chased that path for a while, but i still want the car universal as i want to do local circuit and motorkhana days. I have been slowing increasing the power, increasing turbo sizes from gtx3076-gtx3582-gtx4088-gtx4202 to currently having precision 7675. As i made more and more power it was getting hard to put it down so i was searching for a R32gtr and then they became unaffordable for me so i bit the bullet and went AWD on the s13. Slowly gathering parts for the conversion, i didnt want to commit until i had everything.Tinkering away in the shed i got my hands on a frontcut for dummy assembly, once i was happy with engine position i just started stripping my car apart and threw it in... (well not that easy.... but it works!) anyway here is a few pics of the cars journey.
rb25/30 built by Matt Sims Performance
PPG H dogbox
Precicion 7675 turbo
haltech elite 2500
ets pro awd controller
  • Like 8
https://www.sau.com.au/forums/topic/470754-s13gtr-awd-s13/
16 hours ago, IT15ON said:
Awesome project. I recently put a gtr rear diff in my S13 and wondered how the front one might fit too, what sort of times has it run?
I have only raced it at MOTIVE Drag Battle at Cootamundra as i havent finished getting the car ANDRA teched yet. We were chasing some lost boost problems, finally found what caused it and snapped the mainshaft in the gearbox as i grabbed 2nd gear on the next pass. As the DVD isnt out yet i cant really say how fast i went.
  • Like 1
https://www.sau.com.au/forums/topic/470754-s13gtr-awd-s13/#findComment-7833294
17 hours ago, ActionDan said:
So what sump did you use and is this RB25 (Stagea) AWD gear or GTR AWD gear? Unbody shots plz
all r32 gtr gear, baffled gtr sump. haven't got any underbody pics, ill try remember to get some next time its on the hoist. rather drive it atm than have it on the hoist.
heres a couple of pics i had on my phone, probably what you want to see anyway
included one of the shortened gearbox mainshaft from drag battle
  • Like 4
https://www.sau.com.au/forums/topic/470754-s13gtr-awd-s13/#findComment-7834770
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
