R33 GTR engine overheating issue - low boost
Hello,
Just come back from a track and tested my car in high temp weather, around 25-28 Celcius
My actual set up is 1.4 bar and around 500hp.
Upgrades:
- Mishimoto 50mm radiator
- Mocal oil cooler
My car actually lasted one full lap on full boost, around 4 km of the track. I am experiencing big overheating issues, then my boost drops down rapidly to around 0.8-1.0 bar. The water temperature hits the H mark.
I still have AC radiator and thinking to remove it if necessary and also move the oil cooler to the side of the front bumper so the water radiator can have better air flow.
Maybe there are any smaller AC radiators on the market so can be used instead of OEM ones?
What else i can do to reduce the overheating issue?
You guys in Australia experiencing hot weather, how do you race your cars in such a high temperatures?
I need my car last around 10-15 minutes one session on full boost so i can use my 500hp not one lap....;/
Aftermarket Spal fans. Maybe i should get better fans first. That is a good idea.
How to bleed properly cooling system in aftermarket Radiator MIshimoto? I thought it bleeds itself...no? I had to take out the cooling radiator some time ago so maybe i done something wrong i dont know. My car also has a new map so it can be everything now :224_monkey:
One of my spal fan stoped working, i did not expect that.... . Some shitty spal fans.
What fans are you guys using?
Are the mishimoto fans with the shroud way to go?
I am actually using spal va10-ap10/c-61a 12v x 2
By the way the cooling bleeding was ok, i did not noticed any air inside the cooling system after 20 minutes of driving. But thanks anyway for letting me know.
How much air needs to come out and how would i know there is no more air in the system?
So i start my car and open a bleed screw and what else? Wait 10-15 minutes? How much coolant needs to come out over this bleeding screw?
Also do i have to keep the main valve of the water radiator close or open during this bleeding process?
I have read somewhere that i need to drive first and worm up car good then open bleed screw and ll the air goes up... no?
I'd recommend installing a coolant breather tank. You can get knock off greddy ones from ebay for cheap and since I've done mine I've never had coolant issues, and it's constantly bleeding itself from the head and radiator when running. Most overheating rb26s are due to not being bled properly and one of these takes the guess work out of it.
If you've overheating on the track at speed it's not your fans.
After you had been on the track was there a lot of coolant pushed into the overflow tank?
My method of bleeding coolant that has always worked: Cold engine, open radiator and take out bleed screw. Slowly top up coolant until a small stream comes from bleed, you will see little bubbles coming out. Once the stream looks like no more air is coming out put the bleed screw back in a few threads. Start the engine with the heater and fan on full. Keep the radiator topped up as the engine warms, give some small revs at times to help it flow through. When hot air comes from heater in car undo the bleed screw and allow any built up air out until some steady coolant is rushing out. Put the screw back in and do it up, top up radiator and overflow tank then take it for a drive with heater still in full. You'll notice once it cools down it will suck some coolant in, that's normal, just top up overflow to max mark and that is it.
Throw your American Spal shit into the bin.
Install the OEM shroud, OEM fan blade and a good condition fan viscous hub.
Raced my car last summer is 38+ Celsius degree water, water temperature never exceeded 110 degrees. And I'm sure my car made heaps more power than yours.
  • Like 6
This.  So much this.
And when it comes to bleeding.....several times we have had to jack the front of my car up whilst bleeding the cooling system to convince it to burp the last air out of it.  Even a fancy bleeding funnel into the radiator was not as good as jacking it up.  It is also worth having several goes at bleeding it up with short drives in between, just to try to shake lose the problem spot.
While I completely agree that an engine fan and shroud is miles better, I though spal fans were supposed to be the tits if you were so inclined to run an electric fan?
I didnt check it so i dont know.
I just got my second fan back working, so i am done with one thing. I try to bleed it the way you said.
I also notice that my spal fans were the weekest on the market from the series. I just bought a new one with bigger engine and the air sucking is much stronger.
Anyway, i had a lot ot things to improve about the cooling.... everything i guess...
Cooling breather tank is also good advice i think, thanks!
I am going back on track next week so will see how my car performs.
    • How much is it to re-uploster?  Well that's a "how longs a piece of string?" question !  And I answer thusly: "twice half its length! " . . . . . .  Seriously you'll have to chase multiple quotes for that one from different uphlostrerereres !  Ask around, in your area and on the forums, chase reviews and most of all see the finished product in person cause photoshop is a wonderful thing !
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
    • Oh and how is the rattle when foot is on the clutch ?
    • Did you get the sport or track ? From what the documentation says the uniclutch has a small amount of movement to disengage.  So your story of tricky pedal setup seems common.    Hopefully you got it bled up too, as the bite point moving around is usually either plates wearing in or air in the line.
