The switch part, is the switch you use to turn the lights on and off in the car.
The test I had was to determine where in the line it is, but on a quick rethink, if it's only blowing when you turn the switch on, then it's the wire from the switch, to the headlight that's got the short.
Now it's a case as GTS said, of physically finding the fault.
The fault could be:
metal has broken through the loom. Known as a rub through. Places to check: anywhere the wiring has been messed with in the car, particularly firewall grommets if extra cables have been passed through.
Check the inner guard linings, you might be rubbing through with a wheel, particularly if the vehicle has been lowered.
Also check for anywhere there could be high heat, especially if heat shields are missing.
Double check any wiring at the head unit too if someone has messed with the headlight wiring to pick up a feed to dim the headlight at night.
You could also just have really old cabling that is literally falling apart, though, this is more likely in Euros than in an old Nissan in my experience.
