garage clean out! new and used parts. rb26 top brand
1. New Radium High volume external pump surge tank. $500
2. New JMS FUELMAX single pm2000 40A (boost up voltage from 14v-20v adjustable and ramp in function, active when boost or 5v, much better than kennebell bap) $500
3. A lot New and used aeroflow fittings and silicone hose(an 6 8 10 12 full flow push on hose end, 8 orb-6 8 10an fittings efi fittings, etc) want sale as a package.  $500, buy new will cost you over $1200. enough build one car surge tank fuel system.
4. new nitto head drain rb26. $150
5. new platinum rb26 cas bracket. $200
6. used reimax adjustable cam gears. $120
7. used ross trigger kit rb twin cam. include sensor 700kms old. $400  (new $600)
8. r34 gtr standard harmonic balancer.  perfect condition 48000kms old $100
9. r34 gtr vspec2 nur  crankshaft, con rods, pistons and camshaft(unknown spec)  all in perfect condition. 48000kms old. $500 the lot.
new parts are still seal in box never been opened.
17 minutes ago, Dave76 said:
Is there any markings ,brands one the cams or size
Hi, unfortunately we couldn't find any brand or size of these camshaft. i guess they are come from reinik jp, because the car has a lot reinik parts when it just arrive aus.
  • 3 weeks later...
    • Yes, but 2 things of the top of my head, 1. Legalities of nitrous on a street car. 2. No chop chop. I fully understand that there's much cheaper ways to make power, and whilst a wet 50 shot is fairly cheap to install, bottle fills are expensive, and bottles always need to be refilled, and nitrous also has its own inherent issues with reliability, and tuning, from my experience of others using nitrous, it doesn't take alot to lunch a engine real quick if something goes slightly wrong when spraying, if I wanted a big chunk of additional powers, a spooly boy would make alot more sense, disregarding the additional engineering, supporting mods and other logistical issues of sticking a spooly boy on a car that came naturally aspirated from factory  In the end I'm not racing for sheep stations, and I don't really care if people make more power, or are faster than me, or spend less, or more than me, the only thing the car needs to do is drive around and make me smile, which it is doing now Really, I just want a shiny new intake to look at when I'm cleaning the engine bay, and of course, some more induction doorts, and maybe even that 5kw for that elusive 200hp cherry on top that I might get If the FAB9 intake plenum, TB and air filter box thing doesn't eventuate for whatever reason, Plasmaman do one, not as fancy looking, and a fair chunk of more cash is required when including the TB and other bits and pieces that are required to install it, but, it is another option that is available to me if FAB9 one does fall down (but I really, really.....really, want the FAB9 one though) TL;DR. You want what you want
    • Been so long since I have been here,seeing SDU is dead. I had that problem on my gtr in 2006 but luckily there was no engine damage,it was inspected by Hytech Engines,race bearings and extended crank collar put in and that was about it. Hopefully yours is sorted now.
    • Would it not be cheaper to just spray nitrous?
    • I've got cash, it's the NA LOLS I'm after now Plus, I've had a few boosted cars, and it is soooo easy to turn a reliable car into a unreliable drivetrain eating money pit monster by just paging up and chasing more My power goal for the NC is to try for a reliable naturally aspirated 150kw or 200hp atw (I'm old, and the old naturally aspirated cherry of 100hp per litre is a goal that I would like to hit), no more is really needed for what I use the car for,  so a additional 5kw is what I'm chasing now,  that 5kw is about $3k away, I think....
