Aftermarket headlights?
Hey guys,
First post here :) hoping you can help since I can't seem to find any info anywhere...
First 2 pictures I've attached, show color changing lights. Next 2 pictures show when turning the orange indicator sort of goes around the headlights and then reverts back to both headlights on.
What kind of lights are these, and where can i find them?
Thanks
https://www.sau.com.au/forums/topic/470784-aftermarket-headlights/
Very insightful but I don't think thats how stock headlights work. Would appreciate if someone could point me in any direction for this?
I think you will find that you need to break open the headlight. Gut them, then replace with LED and controller circuitry.
This allows you to create whatever pattern/colour you want.
Don't expect them to last though (from what I've read).
BTW if you're interested in retrofitting, you can follow that linked thread I put up earlier. I have a bunch of projectors (waiting for RX350 ones to arrive from Japan).
I'll be posting my findings soon-ish.
Splitting the housing is fairly easy, glass lens + thick plastic housing = bake in oven and pull apart.
  • Like 2
Just make sure you set the oven on fan forced not grill. i Learnt that the hard way lol
  • Like 1
Lol yeah first time I melted the housing. I now use heat gun, safer but takes longer.
Morimoto Mini H1 6.0 5.0 projectors (I bought them years ago, never used it), going to paint the surround and assemble tomorrow. Will sell after Monday's track day.
  • Like 1
Morimoto Mini H1 6.0 projectors (I bought them years ago, never used it), going to paint the surround and assemble tomorrow. Will sell after Monday's track day.
if you sell them i might have a mate keen on them
I just did pretty much what you looking at minus the demon eye. I went with the D2S and led lights in the housing. As stated above I also sourced my D2S projectors from the retrofit source (demon eyes not my thing) everything else I pieced together from eBay. IMG_4162.thumb.JPG.e1ecaf7cb2f5e37797ba4ebfe517ab7d.JPG
Found some nifty connectors and a tad bit of fab made my own harness to a none forgiving existing hid kit
Cut a secured led strip into glass. Back in the oven at 170 for 10-15mins with some additional butyl (also sourced from eBay) and together she went IMG_4619.thumb.JPG.c758c7187fef481e7d60a5f3b3095601.JPG
Only thing I'm trying to figure out now is whether I want to tint (left housing) or not (right housing). Turn signals will be smoked so leaning towards a matching look.
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
