Was having a look online and read a few places that a rb30de engine as long as it's series 2 is fine to use for 30/25 turbo build so long as you change the cams and pistons as I was going to anyway. Is this true because if it is my mates got a spare rb30de s2 with water and oil lines already that I can have so would save a bunch of money on doing so.
Cheers guys.
https://www.sau.com.au/forums/topic/470787-rb30de-for-3025-build/
43 minutes ago, KiwiRS4T said:
You can use stock pistons if you are poor. I think you'll find the cams are in the head.
Will probably upgrade pistons just because it'll all be apart. And yeah, was a copy and paste from vl forums. :P
53 minutes ago, iruvyouskyrine said:
You don't need water and oil lines if you are just going RB30DE, the water and oil lines are just for the turbo.
Going to be turbo. Only just got into the planning phase so still doing a fair bit of research and planning out the go.
Once I've mapped everything out as far as all parts used for certain components I'll do a write up and can get critiqued on the optimal way to progress towards my goal.
End goal is MAX 500RWKW, tuned to say around 350ish - Want it for Race Days, Street driving/weekending occasional weekly use.
Edited by Bilga
Goal Output: 350RWKW, Maximum reliability.
ENGINE
    Top End
                - RB25 Head
                - RB25 Camshafts
    Bottom End
                - RB30 Block
                - RB30 Crankshaft
                - RB30 Pistons
                - RB30 Rods
    Turbo
                - Garrett 3076 Top Mounted Turbo
    Other
                - Stock Water Pump
                - Stock Oil Pump
    Fuel
                - 1000cc Injectors
                - Bosch 044 Fuel Pump
                - HKS Fuel Rail
                - Billet Fuel Filter
                - SARD Fpr
                - Speedflow Fittings
GEARBOX
                - Stock RB25 Gearbox
                - Exedy Heavy Duty Clutch
                - Nismo Shifter
DIFFERENTIAL
                - Nismo 1.5 Way
                - 4.11:1
COMPUTER
                Not sure, Haltec, Powerfc, Vipec
Go to town on critiquing. Would love to get the optimal parts for my goal, within a good price as cheap as necessary but do want it reliable.
8 hours ago, iruvyouskyrine said:
Right your thread says RB30DE so was confused. No way 1000cc injectors and a 3076 will ever make 500kw but will do 350kw no worries
Yeah, I changed to just aiming for 350kw. More reasonable for my budget and my first build. The only thing I think I might change from that above list is just getting some upgraded cams, from what I've read and seen others do they've achieved my numbers with a pretty similar setup. Do you think that the listed above build will be pretty reasonably reliable at about 350kw?
I've just about completed my 2530 depending on power goals is not a cheap build. I hate to add the final figure but all I can recommend to it once do it right. Remember poor man pays twice
List of mods include
Series 2 rb30de block
Ported rb25 head
Tomei valve springs and retainers
Camtech 272 cams
Garrett gt42
Npc twin plate clutch
Bosch 2200 injectors
Microtech lt16c with flex tune
List goes on
If you buy a neo head and intake you'll save money on the reg and fuel rail plus all the other benefits like solid lifters.
My fuel system is maxed with 1000's and walbro 416, change the 044 pump for a bigger.
Going to use the head and any other useful salvageable parts from the engine from the car I buy 33 gts-t.
Ported rb25 head
Camtech 272 cams
Garrett gt42
List goes on
I think i am going to go with the option of doing it right first, it's going to be in the build phase for a long time since I can't drive it anyway for another year so there is no rush. So It's going to be well worth it when it is done.
Edited by Bilga
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
    • Meh, At 60 years old, I have been doing dumb stuff for much longer than you mate, I am the true King And unfortunately I cannot be a maroon, as I am not brownish red As for not getting ITB's, the plenum intake will apparently show typical gains across the board and increase induction noise a bit, but, have all over less dort than ITB's Cost difference for the extra ITB dorts was significant though, the total parts for the plenum set up is "around" $2kAUD plus shipping, the ITB's were $4kAUD plus shipping, I was contemplating really hard about paying the extra $2k for all of the dorts, but weirdly, some form of common sense, from listening to the platform experts prevailed  As for the NA mod hate by some, I've had a few boosted cars, with all their inherent issues, I'm now looking at simplicity and legalities for a street car, maybe I'm just getting old, and I'm quite happy to spend some of the kids inheritance, 5kw at a time 馃ぃ And think of all the money I'll be saving on consumables that something with boost needs, like engines, gearboxes, diffs, clutches,  tilt trays... etc. etc. etc. 馃お
    • Haha.  I wouldn't say I am either but I've definitely been around it plenty.  I'm guessing you know the dial in is basically to make a handicap to level the playing field between racers.  The car with the slower dial in goes first and in theory if they run their dial in time and the faster car also does then they cross the finish time if they also have exactly the same reaction time - if you go faster than the dial in them you lose, but if you are too slow there's a good chance the other person will get to the finish line first. I'm normally supporting other cars but they were all pretty dialled and were egging me on to race as well, here's one of the cars I tune (Starlet) which ran within like 1 hundredth of its dial in through the competition: https://www.youtube.com/watch?v=inEBu-d9Gn4&t=69s
    • Where ever the fuel reg gets it reference is what I use to T into for map reference been a very long time so where it goes to plenum/runners I have no idea but never had issues.
