  • Replies 101
http://members.dodo.com.au/paul/software/r...ator-nissan.zip
comes with all my pitcars and savegames. also has rrrage's pit cars so theres pretty much everything there, also my records as well :) also has the version update applied to it. just unzip and you should run simrconfig.exe once and choose video res, its the first ???????? button. then just exit (last ???? button) and run the game.
thanks heaps.... now i'm off to play :)
  • 2 months later...
can some 1 please re host an pm so i know when it has been hosted.. i want this so bad an everytime i tried 2 download it wouldnt work.. thanx
here you go... and anyone else who would like it.....
clicky clicky
hey guys
im having problems gettin the real car simulator to(nissan version) which i downloaded from the link above to work, im pretty sure that everything is unzipped into the folder i created.
but when i click the icon the screen goes black (as if the game is bout to start) and then it goes back to windows...
can anyone help me?
cheers
Mitch
someone plz plz plz host it...and let me know..this sounds fun
look at my post above.... the link is still active
clicky clicky
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
    • WRXs are a pure pleb boring car these days. You need to get an STI to even get close to what a WRX used to be.
