  • Replies 101
no gti-r's. :D yeah i have the demo of the toyota one - wouldn't mind having the full v. :D
you earn cars by completing championships etc. or maybe it has something to do with your points in the bottom right corner that goes up after races.
no idea where you can dl cars.
Guest
