But remember the more you raise the rail pressure and ram more fuel throught the injector you change the spray pattern
And you have to leave some headroom in the fuel pump for boost. :headspin:
Around 45psi rail pressure.  its a trade off.  aftermarket inj. cost tons, raising the rail pressure costs F A.  If u had the coin to need 65psi rail pressure u would change the inj anyway.
And since most fuel pumps are rated at 73.5 psi, you would only have 8 psi left for boost. That's not much :wassup:
How long will your fuel pump last if you fit a FPR - ie compared to if you didn't fit a FPR ??
A) The same as if you didn't fit the FPR ?
B) Less because you are labouring the Fuel Pump ??
c) More because of some unknown reason ??
I suspect (B)
To get that sort of power I assumed you would already be on boost. Surely an aftermarket rising rate regulator will allow you to maintain a slightly elevated fuel rail pressure and then rise it to 65psi by the time you are on full boost.
I don’t have a problem with using a RRR, but if you are pushing that type of power (and I am assuming you have replaced the turbo, fuel pump, computer, intercooler) then surely the cost of injectors is worthwhile even if it’s just insurance for your motor.
How come I get 92-94% injector duty quite regularly with 0.85 bar and standard turbo?
One day it hit 100% when i wasn't looking but it seems to have these microsecond spikes like 65% when you've barely touched it.
Car is running rich?
Yep, that means full boost is 8.5 psi. :rolleyes:
You should see my fuel bills! Jeez man. Weird thing is, at the track the exhaust goes brown like it's running lean.
I'm thinking of putting a 2nd hand SAFC in there till I can afford an emanage and a good tune. The ECU I have makes it run so smooth but I think it's just putting way too much fuel in.
Magic1s GTS has 435rwhp on stock injectors and uprated pump,this is the most we have seen sofar on stockers and we have never had any problems at high fuel pressures.
We will fit a bigger pump and see how we go.
This power is in shootout mode.
I see around 80% duty cycle from my 550cc injectors with no FPR and Bosch 044 pump with around 312kw@wheels.
That's about right, I have seen around 565 to 570 cc's out of injectors rated at 550 cc's.
So 570 X 80% / 1.34 - 60 = ~300 rwkw
Your 312 rwkw is a pretty good effort. :)
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
