Built RB26 Set up, Motor, ECU, TURBO
EOI Considering selling my set up. (Motor, ECU, COOLER, COOLER PIPE KIT, Fuel SYSTEM)
AS A PACKAGE (motor, cooler and pipes, fuel system, and ECU $21,000)
- Fully built RB26 motor + ECU + Cooler and PIPING + Fuel System
(About 1500KM, Made 353KW @ 21psi only, cams still dialed at 0. Have majority of receipts.)
****Comes with Power FC J Jetro (Mafless) with 353KW tune***
HEAD (R34 Head)
  1. HKS 272 Cams 10.8MM lift
  2. Tomei Dual valve springs, retainers & buckets
  3. Tomei Metal intake gaskets
  4. Tomei Head gasket
  5. Tomei Exhaust manfiold gasket
  6. Tomei Fuel Reg
  7. Adjustable Cam gears
  8. Reshimmed Head
  9. 3 Angle Valve job
  10. Delphi 1650CC E85 injectors
  11. New intake valves
  12. All new guides
  13. Head drain kit
  14. Stock Ports
  15. Custom billet highflow Garrett GT3582
  16. TOG steam pipe manifold (lifetime warranty)
  17. 45MM Turbosmart wastegate
  18. Splitfire coilpacks
BLOCK
  1. Balanced Ross Pistons 86.5MM and H Beam Rods (HPC coated skirts)
  2. Crank Collar
  3. ARP 2000 Head Studs
  4. Grub Screwed Crank
  5. New timing belt kit
  6. Reimax Oil pump Gear
  7. Tomei Sump Baffle
  8. Tomei head restrictor
  9. Extended sump
  10. FULLY Balanced rotating assembly
  11. Less then 1500KM NPC Ceramic Button clutch
  12. ALL new gaskets and hoses
INTERCOOLER
100MM cooler rated to 800HP (Autobahn 88)
FULL custom stainless steel piping
Fuel System
- Intank 040
- 2LT surge tank with twin 044 to dual filters
Edited by Cateans05
https://www.sau.com.au/forums/topic/470816-built-rb26-set-up-motor-ecu-turbo/
  • 3 weeks later...
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
