Anyone seen this in a Yellow Jacket Coil Pack?
Yet another misfire,
R33 Gtst unmolested
intermittent, yet continuous when occurring. Subsides after a minute or so
Drives perfectly 90% of the time
New Plugs, new fuel filter
Did attempt to wrap the packs to no avail.
Cash is tight at the moment, trying to avoid replacing these again.
Thoughts and opinions would be appreciated.
Thank you
9 hours ago, 89CAL said:
If you can't find any info on yellow jacket coil-packs dying on these forums, I'm sorry to say you obviously haven't searched hard enough
Mate you'd be surprised... The canadian stagea owners swear by YJ's and the shit Autobahn88 sell...
You can lead a horse to water...
Aaand, i never did get my refund or replacements for my 6 coils melting.
The search function on the forums is pretty awful. I think the guys here have just seen a few threads in their time from browsing, but these don't always show up in search reliably.
First thing's first: suss out which one is playing up. Mine used to do it when idling, so I was able to pull the wiring loom from each one until the idle didn't get even lumpier, then I'd know which one was problematic. Then I tested that coilpacks in a different cylinder to rule out the wiring loom as an issue - the problem followed the coilpack.
Once you've done that, check out the coil spring - it may be too short or not seating properly. Either buy a second hand OEM one to replace it in the meantime or contact Paul from Performance Wise - he was pretty good when I had coilpack issues and sent me one for free when I sent him back the faulty one. I ended up with another issue down the track though and I'd had them for 5 years so I figured it was time to update - went to splitfires and they haven't missed a beat I have to be honest. The YJs were good as a bargain for a few years, but long term not so sure. Time will tell if the splitfires are much better.
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
