  • 9 months later...
i ran a 10sec pass in my 2012 R35 GTR with just a midpipe, catback, and air filters. everything else was stock. 10.8 to be exact. i didn't even have a tune.
so with a tune and midpipe you should definitely do it, though if you were getting it tuned i would do aftermarket air filters, fuel pumps, injectors and downpipes as well at the same time since you are going to need a retune if you get any of those parts later on the quest for more power.
  • 2 years later...
My 2014 MY 2015 runs titanium midpipes. No idea what brand, but not a bad note. Have not had a tune as yet. Fitting Cobb catless downpipes, upgraded fuel pumps, ID1050x injectors and Big SF carbon intakes at the moment and will have a tune on completion. Not sure when as I managed to shear the turbo manifold stud on the left downpipe, the one at the 8 O'clock position. It was the last one so pretty pissed off, even more so when I broke a 3mm drill bit trying to drill it out. Off shopping tomorrow for a rescue bit and maybe one of those hollow diamond bits to drill around the HSS broken one. At least with this mexican beer flu around I have plenty of time to waste on cars.
Also agree with BLISTIC, hardly worth a tune for midpipes alone. Once you start down the dreaded upgrade path, watch out for the Kaching meter. Bought a set of pipes and then discovered there is no Accessport tune for that. Got to add the big intakes, fuel pumps and injectors which requires I think at least a stage 2 or maybe stage 3 tune to sync everything. Maybe next week if the world hasn't shut down.
  • 1 month later...
All done. Car has gone from a beast to a monster! Did a COBB stage three tune and the car is running so well I'm not bothering with a dyno. Only downside is having to drive with the windows down to savour the the brute note.
Literally saved around $3K on installation quoted costs, so more than enough to pay for the skin grafts to knuckles etc.
Having a hoist was a big advantage, although the trickiest part was installing the pod filters on the intake pipes. Actually resorted to KY!
The big beware is the downpipe nut removal. NISSAN use these bloody one use pinch nuts which can be problematic getting off. See above. It was at least relatively accessible. It could have been much worse and this engine has 14K on it. Not sure I would risk it with a high mileage one. Oh, and that sheared stud removal took me four days and a lot of swearing!
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
