Attesa not working
I have a S1 C34 that is manual converted, with power fc. I have the secret squirrel mod done. It previously had an extreme TSC that I removed thinking that may be the cause, but no change. My AWD has never worked since I bought the car 2 years ago. When I purchased the car the owner said the Attesa needed to be bled since the gearbox had been out. I bled the Attesa and it still doesn't work. I can hear the pump prime when I turn ign on and it runs occasionally while sitting at idle. I have had the awd and abs lights come on and stay on after sitting idle for long periods. I don't seem to have any fault codes to try and work out why it doesn't work. I have checked that the Attesa ECU is receiving a TPS signal and that is all ok. I'd really like to get it working, as it is hard getting the power down just through the rear wheels. I've been reading and am thinking either pressure switch or accumulator. Is there any way to check these for sure?
Edited by fmlycar
https://www.sau.com.au/forums/topic/470860-attesa-not-working/
Crawl underneath the car and have a look at sensor and ABS rings on each axle.
Mine had an axle popped out of rear LSD housing causing ATTESA and ABS not working properly by sensor not reading it properly, sometimes it's both, sometimes it's either one.
The width of sensor should be in-line of the ABS ring as in =o= if you get my drift.
One of the rear abs rings (passenger side) has a crack through it. Would that make a difference? I put it in gear while it was off the ground and it has drive to the front left, but I can stop it with my hand
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 馃槢
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
