Skyline r33 fuel injectors guidance
Hi guys my car fuel consumption is so high it's doing 250 per tank 55 litres means 20 litres per 100 km . So had oil nd filters changed mechanic said spark plugs r ok .
so now I am thinking to replace its fuel injectors. Currently looking on eBay but confused which ones are good for me. 750 cc nd 550 cc company brand my4 . Also can someone tell me do I have to change other things to replace the injectors on my car . What's the factory injectors info like (what cc or brand ) etc . Can I use the same coil pack for new injectors as it's already on the car I mean factory coil pack or I have to change coil packs too according to new injectors? Thanks guys hope to get some good information cheers
https://www.sau.com.au/forums/topic/470864-skyline-r33-fuel-injectors-guidance/
There are a number of things I'd check before replacing injectors dude:
  • Oxygen Sensor
  • Intake/Filter - check for blockages
  • Temp Sensor
  • AFM - might need a clean
  • Thermostat
  • Vacuum leaks
All of these things are far cheaper and easier to address than injectors. Have you done the basics? Low tyre pressure combined with old/thick oil can actually affect fuel consumption pretty dramatically. Are you running good, 98RON fuel?
Maybe try a reputable fuel system/injector cleaner too.
  • Like 1
You can't really change the injectors with the stock ecu. You could get them cleaned and tested. Did the mechanic actually pull out a spark plug to have a look? By the time you have gone that far one would normally change the plugs anyway. If you look in the DIY section you will find a guide to changing the plugs. get new ones gapped down to 0.8mm. Give the coils a good clean and if you see any burn marks where they have been shorting you should ideally replace them with OEM or Splitfires (or at least spray or wrap them with insulating tape).
If you can go through the list in the previous post. Dirty air filter is a top suspect. There is a DIY somewhere on how to clean AFM. If you want to know how to do something Google the question first and you will usually find the answer. If you don't usually do your own work get a few tools and start now or your Skyline will keep you poor!!
  • Like 1
  • Oxygen Sensor
  • Temp Sensor
  • Thermostat
  • Vacuum leaks
This is a great list!
Before doing anything related to the injectors check all these things above first. Also put in new spark plugs, new fuel filter and new oil. After doing all the things listed above start writing a log and the come back with those results and we can help further. Have fun!
  • Like 1
Hi guys it's temp needle never goes up it always few minutes to come normal level so it's can't be temp sensor or thermostat. Um just gonna change its air pod which not much $$$$ and will clean AFM thanks. But whenever I start cold engine like next morning it's turn up but after couple of rounds it's goes off . But day time it's alright just 1 round nd runs smooth. Any idea why ?
There are two temperature sensors, one for the dashboard gauge and one for the computer to operate the fueling tables, so yes it still could be the cause of your issue.
O2 sensor
Computer Temp sensor
and bad/ stuck thermostat.
They are your most likely culprits.
O2 sensor
Thermostat is a likely culprit. I'd say change it either way.
This is incorrect, as missleman said there it 2 senders. If the sender for the ECU has died it will be reporting full cold temp and as such the ECU will compensate by adding lots of extra fuel as it thinks it is in very cold conditions. The temp sensors are on the inlet manifold near the top radiator hose. The dash one is the single pin and the ECU one is the two pin plug.
Thanks for your advice guys
I clean the AFM
had look on oxygen sensor it looks ok
spark plugs on the way to be replaced
had look on temp sensor not sure they working properly but looks ok too
but I can tell yah my car has bad starting in the morning. Daytime it's ok but morning time it takes 2 push or I have to accelerate to help engine turn up . I am really confused if it's temp problem then it shouldn't have starting problem. Looking to hear you again please
At this stage I would stay patient until your spark plugs arrive. Put them in and see if that fixes your issue, as it may well be them.
After that, I would start by replacing the O2 sensor, temp sensor (2 pin) and thermostat. Sensors can be got for around $40ea and the Thermostat around $50.
We've given you the advice mate, just have to follow it :1310_thumbsup_tone1:
  • Like 1
  • 1 month later...
Hi guys um back with same issue I have replaced spark plugs nd splitfire coil packs but car still sucking the fuel same way nd in the cold morning still has same bad starting engine just stall sometimes it seems like motor has breathing difficulties but not sure what it is any suggestions please. It's r33 by the way um posting pics very soon it's got front facing plenum, front mount inter cooler apart from that it's a stock car. Sucking fuel more than 20 litres per 100 km don't know why
    • Duncan:- it affect both sides.  Driver side is worse.
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
    • The consult isn't even OBD1. It's a Nissan Consult. Proprietary.   Re read everything I've said. I specifically say, put down the laptop/tablet. Understand, and review the issue first. Logging voltages is the same as logging the converted value. Things like O2 that you say to log, is unusable for this, whether it be the voltage, or the value the ECU thinks.   The fact you don't know how to diagnose without looking at the computer, is exactly what I've said multiple times is the issue for why techs these days can't diagnose the fun issues with cars.
