Wrecking Skyline R33 GTS-T Turbo Manual. Whole car available for $8000 without the wheels pictured. can be registered, clean title and clean body, no repairs before. Put a carpet in and engineer the roll cage and it can be registered.
RB25DET Engine - $2200 as it is, negotiable by removing certain items.
- ARP Head Studs (no more than 50kms old)
- Head full reconditioned with valve seals replaced
- Permaseal Multi layer steel head gasket (no more than 50kms old)
- Rocker cover gaskets replaced not long ago (no more than 50kms old)
- Gates Racing Timing Kit with water pump (no more than 50kms)
- Kinugawa Turbo, GT3076 equivalent
- Iridium Spark Plugs
- Splitfire Coilpacks
RB25DET Turbo Gearbox $1800 - NOT NEGOTIABLE
Manual Conversion Kit - $2200 (available unless gearbox is sold)
- Lightened flywheel (no more than 50kms old)
- Exedy Heavy duty button clutch (no more than 50kms)
- Master & Slave Cylinders
- Clutch Lines
- Pedals
Complete Full adjustable suspension arms set - $600
- Adjustable Upper Control/Camber arms front pair
- Adjustable Upper Control/Camber arms rear pair
- Adjustable Lower control arms, front pair
- Adjustable Lower control arms, rear pair
- Adjsutable Front Castor Arms
- Adjustable Rear Toe Arms
- HICAS Lock Bar
- Greddy Boost Controller - $300
- DBA T3 front & T2 rear brake Discs - $250
- Front mount intercooler kit - $250
- Alloy Radiator - $150
- GT-R  carbon fibre Bee-R style wing extension ONLY - $450 (does not include the GTR spoiler body/base)
- Genuine R33 GT-R 400R (aluminium twin blade spoiler) - $1200
- AGI Bolt in half cage - $600
- Genuine Sabelt 4 point harness, driver and passenger - $200
- Whiteline Sway Bars, Front and rear - $300 (cosmetically worn but still works fine)
- Ohlins Adjustable Coilover Suspension - $2000
- R34 HKS Full Turbo back exhaust - $350
- Greddy Catch Can - $50
- Greddy Strut Brace - $200
- B-Pillar Floor Brace/Monke Bar - $200
- Headlights Pair - $600
- Front Bar with Fog lights - $450
- Grille - $150
- Bonnet - $250
- Driver Door complete - $200
- Wheels with good tyres - $1000 (not negotiable, I'd like to keep them but would let them go for the right price)
- Reo bar - $150
- Side Skirts - $150 pair
- Rear pods (in gun metal grey) - $100
On 02/07/2017 at 2:27 AM, MagicPants said:
Seat for sale ?
sorry for the late reply, yes they are for sale, have the pair for $400
  • 4 weeks later...
  • 3 weeks later...
On 8/22/2017 at 5:44 PM, MagicalZorse01 said:
Interested in the drivers door, is it fully complete? And also would it all work on a series 1?
The door is mostly complete, window and regulator is there and working. only door trim is missing. Will work on series 1, PM me.
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
