I removed my Hicas with an elimination kit, didn't cut any wires whatsoever and I haven't had any issues at all.
Did you remove anything besides the hicas rack? Did you cut any wires?
Try disconnecting the battery, leave it for 10 minutes and pump the brakes a few times to get any residual power out of the system. Connect the battery and try again
https://www.sau.com.au/forums/topic/470905-hicas-on-r33/#findComment-7835515
Only thing I removed apart from hicas is hicas fuse.. Did not cut any wires.. Thanks mate will give that a go.. Is the elimination kit you used the tomei one
https://www.sau.com.au/forums/topic/470905-hicas-on-r33/#findComment-7835517
