For Sale:
Pewter Grey S15 200sx | 30k Ono | 400rwkw
Hey Guys! For sale is my Pride and Joy, reason for sale is moving onto another car and I don't have the room to keep this one!
I also understand the price seems steep but please read the add for a thorough understanding of the car and where real money's been spent.
A brief overview of the car, it's very tidy, it's always well looked after and meticulously maintained! The car was built by Maatouks and maintained by MRC.
Negatives of the car include the following:
- (Paint) The condition of the paint itself is in good condition but please be aware there are scratches and should be inspected, a respray isn't necessary but would be ideal to complete the build.
- (Brakes) The brake setup itself is fantastic, but upon driving the car you'll notice an audible squeal, which can be annoying.
The following Modifications to the car include:
Running Gear:
Tein Flex Z Fully adjustable Coilovers
Hardrace Rear Camber Arms
Hardrace Rear Toe Arms
Hardrace Rear Traction Arms
Hardrace Front Castor Arms
Solid Mount Rear Cradle Bushings
R33 GTST Rear Brake Setup - with Drum Handbrake (296mm)
(T3 Rotors and PMU800 Pads)
Brembo Evo X Front Brake setup with Alpha Omega Adapters (350mm) with Braided Lines
Brake Master Cylinder BMC57 (GTR Upgrade)
Rays RE30 18" 9.5 (Rear) 8.5 (Front)
Wrapped in Brand New Bridgestone Potenza RE003's
Rear 255/35/18
Front 235/40/18
Engine:
Forged SR20DET (400rwkw)
Haltech Platinum Pro
AEM Electronic Boost Controller
JE Pistons
Nitto I Beam Rods
ARP Head Studs
ACL Race Bearings
New Factory Oil Pump
New Factory Water Pump
New Factory Timing Chain
Nitto 1.5mm Head Gasket
Aeroflow Baffled Sump
New Factory Chain Tensioner
New Factory Chain Guides
Supertech Valves
Supertech Single Valve Springs
Naprac Rockers
HKS 264/272 (12.5/11.9) Cams
HKS Adjustable Cam Gears
Plazmaman Intake Manifold
Plazmaman 72mm Throttle Body
Custom intercooler piping
GREDDY Intercooler Kit
GFB Adjustable BOV (V Band)
BPP Fuel Rail (High Feed)
Bosch 1550cc Injectors With Bosch Connectors
Walbro 460 E85 Fuel Pump with Direct 12v Supply through Relay
4 Port MAC VALVE Boost Solenoid
E85 Braided Lines and Fittings (Black)
Sard FPR with Aeroflow Fittings, Braided Lines
Garret GTX3076 0.82 (V Band)
Braided Turbo Lines
Custom 6 Boost Manifold
Twin Tial 38mm External Waste Gates (V Band) with External Screamer Pipes
Split fire Coil Packs
Tomei Coil Pack Cover
Serviced with Liquid Moly Racetech 10W/60 and Genuine Oil Filters
Custom 3" stainless Steel Exhaust System, with Cannon/Muffler
Custom Oil Catch Can with Aeroflow Fittings
Apexi Hi-flow Pod Filter with Custom Intake Pipe
Custom Pod Filter Box
Alpha Omega Rocker Cover Dress up Kit
Driveline:
Twin Plate OS Giken Clutch Kit
PPG Dog Box 5 Speed Straight Cut Set for R33 Series 2 Gearbox
Braided Clutch Line
R33 Tightly Shimmed Locked Diff
R33 Drive Shafts
Custom Tail Shaft to Suit RB Conversion
Interior:
Bride Seats and Rails
Turbo Smart Boost Gauge
AEM Boost Controller Dial
JDM A Pillar with Turbosmart Boost Gauge (30Psi)
Carbon Centre Console
GT Chrome Door Handles and Gear Surround
Custom Harness Bar
Alpha Omega Gear Knob
Silvia Floor Mats
Double Din Display (Bluetooth, Navigation)
Exterior:
Genuine Factory Aero Kit
Genuine Factory Aero Bar
Genuine Factory 1 Piece ADM Spec R Skirts
JSAI Fibreglass Rear Pods
Origin Roof Spoiler
Genuine Factory GT Wing
Carbon Exhaust Heat Shield
Yashio Tinted LED Tail Lights
Located, Sydneys Hills District
I appreciate your time reading the add!
Any negative comments will be ignored and appreciated if you kept them to yourself.
Any enquiries, feel free to Pm me.
Price is Negotiable.
  • Like 2
https://www.sau.com.au/forums/topic/470931-s15-200sx-400rwkw-30k-ono-sydney/
  • 5 years later...
39 minutes ago, nnina said:
beautiful! any chance it’s still available?! 😍
over 5 years ago....... Take a guess.
:domokun:
Edited by robbo_rb180
  • PranK locked this topic
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
