Dual Tial wastegates and spring choice with MAC
Hey guys,
So I recently switched to a 6 boost high mount running dual tial MVS 38mm wastegates. This will be my first time running this type of setup, target boost pressure will be 30, but possibly 35 psi. Both will be controlled by a MAC valve going back to a Wolf v550. Engine is a built 26/30 with borg warner 9180 turbo.
I have setup the springs in both gates for 23psi, with the idea that the mac valve can do the rest to 30. Can someone tell me if that's going to be OK?
Some people have told me that running 23 might be an issue when time to tune, is this correct?
Cheers.
You are assuming that your set-up will run OK at 23 psi. If you are confident about that - no problem - but if there is any doubt you should have a set of lower springs to hand so that you don't have to return to the tuner for another session. Also if you find that you will be regularly running 35 psi you may want springs for 28 or so psi.
  • 3 months later...
As mentioned above, double check how many port MAC valve you have and if it's not a 4 port, buy one. MUCH better control and you can run softer springs with a much larger range.
FWIW, I'm running 0.9 bar springs and have no issue at 26 psi (bringing it back to 23 up top on purpose) using 4 port valves.
also I'd recommend finding a 12 watt solenoid version of the 4 port mac valve (made by circuit seven on ebay). they control duty cycle range is much greater (40% greater effective duty range) giving you better control resolution as the 4 ports are sensitive.
also a lighter spring in the gate will allow the valve to respond faster. as long as your diaphram to valve area is decent (>1.5), a 4 port will hold it closed with a very light spring.
effective duty @ 30hz for the 4 ports:
5.4watt is 22-62%
12watt  is 14-70%
alve
freq
approx Duty range %
3port MAC-5.4 watt
10
7-90
15
10-89
20
15-86
25
17-80
31
20-80
40
26-68
3 port MAC-C7-HI-FREQ
31
15-85
40
17-82
4 port 5.4 watt
10
9-87
20
16-70
30
22-62
40
25-40
4 port C7-HI-FREQ
10
6-90
20
10-80
30
14-70
Edited by burn4005
  • 3 months later...
i have the same setup
i followed tial’s spring chart for 23psi
for some reason we had boost reach 37 psi
i used two springs not the recommended 3 springs and boost stayed around 20psi
i would start with two and a 4 port mac valve that way you can go 20-40psi
my mistake
i’ve plumbed it wrong
follow Tials instructions PROPERLY and they’ll work fine
    • Had another look at the car and I noticed the fuel pump isn't priming on ignition. I'd taken out the pump from the boot to siphon out the old fuel, so maybe I've knocked something loose or broken a wire putting things back together. Will go back with a multimeter and try to work out what's stuffed. Kinda hoping it's the pump itself thats gone so I can upgrade it
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
