Nismo 365A Steering Wheel BNR32 + White 320KM/H BNR32 Cluster
- 1993 Nismo 365A (365mm) Steering wheel with Nismo Horn button and Nismo BNR32 + S13 Hicas compatible boss. The wheel is in what I would describe a 7.5/10 condition. No tears just a few scratches that are no too deep. Most sellers wouldn't mention but I'm a thorough seller. Sun fade is non existent.
The horn is in 100% perfect condition and so is the 87mm Nismo Boss. Set price $700 USD
- Custom White with blue lettering Nissan OEM cluster set for a 91/8+ BNR32 Skyline GTR in original packing. Price $650 USD
International Shipping $35 USD
Paypal 4%
  • 3 weeks later...
