Nissan Skyline R33 Gtst Series 2 - 360rwkw
https://www.carsales.com.au/private/details/Nissan-Skyline-1998/SSE-AD-4796564
Some of you might recognize this car, old plates were 'GR33DD'
Regretful sale, but i don't drive it as much as i would like to these days. Time for the next owner to take her home and enjoy it.
Last production of the 1998 R33 GTST Series 2 . I am the 2nd Australian owner and it has been flawless for the past 5 years I've owned it. With majority of the hard work already been done by the previous owner and myself, The car talks for itself. Jump in and enjoy it. Well looked after, Very fun car to drive, Handles great, Stops great, very responsive for the street & sounds tough with plenty of power to back it up! Can be driven daily nice and quiet with the exhaust closed or open for a race day with a push of a button by the Varex muffler. Big money spent on quality parts.
It has been driven mainly on weekends only as i have a company truck to drive around in during the week. Paint/Body is in good condition and is washed and waxed regularly. Rust free body. Mechanically always serviced on time by myself & my dad every 5000kms. Always Garaged.
Modifications include:
Resprayed in Nismo 400r Super Clear Red II (Paint code AR1)
Suspension & bushes replaced with Bilstein shocks & springs/Whiteline rear subframe kit & bushes (Adjustable ride height)
Aftermarket rear camber arms
Aftermarket front camber arms
HICAS Lock bar
R33 GT-R Series 3 Red stitched Full interior (Door cards, front seats, rear seats, etc)
Upgraded Dash lights pure white & blue LED
Hybrid frontmount intercooler
Haltech Platinum Pro ECU
Haltech 3 bar map sensor
Haltech o2 wideband sensor kit
Garrett GTX3076R T3 .83 twin scroll turbo
Turbosmart 50mm External Wastegate
6boost twin scroll manifold T3
ARP head studs
Upgraded valve springs
Camtech Camshafts 272/272 in&ex 9mm lift
Greddy exhaust cam gear
HKS 3" exhaust straight through to Varex Muffler 3.5" out (Quiet or Loud with switch in cabin)
Greddy ProfecB II boost controller
Shadowpro mechanical boost guage
Walbro 460LPH E85 Fuel pump
Raceworks top feed fuel rail
Raceworks 2200cc top feed injectors
Genuine SARD Fuel pressure reg
Splitfire Coilpacks
4" steel intake pipe
K&N Pod filter
Plazmaman forward facing plenum
OS GIKEN TS2CD Twin plate clutch (installed 1,500kms ago)
Nismo 1.5 way mechanical differential installed/serviced by Unigroup Engineering
Aftermarket Brake Stopper
RDA 324mm GTR front slotted & dimpled rotors with URAS Adapter kit
DBA Rear slotted rotors
Desmond Regamaster EVO 17x9 +18 square
Federal 595 RS-RR Semi slick tyres
Custom Oil Catch can/Washer bottle
Custom Coolant Catch can
42mm Fenix alloy radiator
PSI Parts Carbon Fibre Air Guide
Sony CD/bluetooth/usb head deck with 4 channel amp.
15% window tints
Nismo front strut brace
ALL intake, turbo & exhaust gaskets have been replaced.
R33 Sedan fog lights (Original Series 2 fog lights will come with the car too)
Aircon has been regased this year, you will be frozen in 2 minutes.
Might be a few other things i've missed, feel free to ask questions.
The car will come with 2x Keys.
Compression test was done September 2016 with good results of 150 - 160 across all 6 Cylinders. New turbo setup was done at this time.
Tuned by Jez @ DVS Tuning making 360.2rwkw @ 25psi high boost, 336rwkw @ 19psi low boost. Dyno sheet provided.
The car runs on UNITED E85 FUEL ONLY. Can be tuned to go flex fuel if you wish with a flex sensor.
Cons about the car:
- Couple of scratches around the body as you would expect for a 20 year old car, but nothing too noticeable.
- Minor oil leak behind the head coming from the half moons.  Will need replacing.
- Front tyres will need replacing soon
NO low ballers
NO swaps or joy rides. Deposit must be taken before test driving the car.
Price is Negotiable, Reasonable offers considered.
Price can be adjusted lower if you do not want the wheels and want to bring your own.
More pictures & videos of the car can be found on my instagram account @98gtst
On 7/2/2017 at 2:49 AM, MagicPants said:
Hey mate, which price is current, this one or the carsales one ?
The one on carsales mate, Sorry have been busy with work. Current price is $17,990 ONO.
Cheers.
  • 4 weeks later...
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
