R33 GTR coolant leaking
I found out lately coolant leaking at the back of the engine under intake manifold. There is a pain on the ass to check this, cant see anything. I think i will have to take out my intake manifold
I tracked day my car on hot weather and after 10 minutes of hard driving on the track all coolant leaked out under high pressure. After next 15 minutes all cooland was out, about 4 liters. Something is not holding right on big pressure inside the cooling system. I did not had problems like this before and have done around 50 000km after single turbo convertion. Never experineced single cooland leaking before.
I am planning to do it myself with some random shop and try to fix the problem. What seals should i change or can be the thermostat?
Where is the thermostat located in the r33 GTR?
I am thinking also about the turbo water lines, what else should i check or change? I have only one shot after i take this intake manifold so i want to change everything i can and all the seals.
I attached the photo where this cooland leaking occurs.
Also this leaking is no all the time, most of the time i drive there is no leaking at all, on normal daily driving or during the night.
Anybody experienced such a problem?
https://www.sau.com.au/forums/topic/471000-r33-gtr-coolant-leaking/
Yeah right under there is T ( for want of better word ) where the feed for the turbo water line and something else ( maybe heater ) comes out of head or maybe too if block. But no surprises you have leak there. Only under high pressure so could just be clamp not holding. Intake off is a prick.
Obviously left hand drive !? Looks weird with brake booster etc on hot side.
4l in 15 min is a big leak.it will be obvious where it is coming out. If the hose isnt split try replacing the clamp. If you spot fix this leak expect another leak to follow in the short term.
At least you will be back on the road driving. No one likes chasing heater hose leaks.
    • How much is it to re-uploster?  Well that's a "how longs a piece of string?" question !  And I answer thusly: "twice half its length! " . . . . . .  Seriously you'll have to chase multiple quotes for that one from different uphlostrerereres !  Ask around, in your area and on the forums, chase reviews and most of all see the finished product in person cause photoshop is a wonderful thing !
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
    • Oh and how is the rattle when foot is on the clutch ?
    • Did you get the sport or track ? From what the documentation says the uniclutch has a small amount of movement to disengage.  So your story of tricky pedal setup seems common.    Hopefully you got it bled up too, as the bite point moving around is usually either plates wearing in or air in the line.
