as topic..
R33 GTST series 1 Auto half cut - KM's Travelled = 83205 km's
so i raped the half cut of the engine and now all bits left are for sale....
ALL PICTURES OF PARTS ARE HERE
Climate Control - $100
Air Vents from top of the dash - sell sep or inc with Dash - $10
Center Console (with the good 'ol auto button) - $30
Whole dash unit inc air vents - $220
Instrument cluster surrounding bit - $10
Instrument cluster with 83 thou k's on the clock - $200
other things i havnt got pics for yet:
Stock front Suspension - exc con - $ 100
headlight wiring loom (from headlights to dash) - $$$
Brake Booster - $60
R32 Gearbox crossmember - $80
no panels of bonnet or sides
anything else i havnt thought of - through your thoughts at me!
email: [email protected] for any queries
https://www.sau.com.au/forums/topic/47102-fs-r33-half-cut-left-over-parts/
  • Replies 48
Posted Images
thanks all for the replys.. i cant keep up with them all - lol
ok... Jules - you know my number :)
Freeze - the ignition i had to drill out the bolt that connects it to the sterring coloumn bit - bit i did it in such a way that you can redrill the screw back in.. so there is no drama in using it... as to the ignition - i'm not sure but i'll let ya know
Penfold - no dramas champ.. i'll grab some closer more detailed pics for you today
everyone let me know your emails so i can send pics to you..
even better - drop me an email : [email protected] and i'll keep in touch there
cheers all
BRAD
hey all... sorry i havtn got back to you's about the pics... i've been getting home from work to late and its to dark to take pics... using the light doesnt show alot of detail
i'll take some saturday day and send them to you all..
sorry for the delday again
cheers
BRAD
wondering if you might want to send the carcus of the half cut, as in the half cut with everything removed, or better still remove everything and cut it in half so i can have the right hand side. i'll pay shipping and some money, but id be doing you a favour as you'd have to take it to the tip anyway
cheers andy
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
