  • Replies 48
Posted Images
Smittler,
interest in both headlights (depends on damage etc)
also need some interior parts, being the centerconsole, possible glove box (depending if my key will open it :D) i might be able to come around and check out that parts if thats ok?
can u pm me details on price and damage etc thanks
mike
hey all.. sorry about the late reply - i'm living up at Laneclin (wedge) (1.5 hours north of perth) at the moment because i'm crayfishing this season... so my net access is very very limited.
R33_KRAZY - sorry champ... i dont have the radiator
elbee111 - sorry to be a noob... but what is a indicator stalk ?
calemb - sorry man.. headlight is gone - i tested it and it wasnt up to scratch to sell.
Tigger - sorry champ... shifter etc went with the gearbox
FR33ZE - hows it going bro - sorry but the xmember went with the box to
13_Devil - no headlights anymore :wave: Glove box has been sold - but your in luck with the center console.
the only problem is that i'm heading back up to lancelin for a week as of tomorrow morning - but i'll be back next weekend.. the center console is an auto one (has the little button for snow etc) but apart from that its spot on condition... if you want we can organise inspection next weekend.. drop me a pm and i'll back to it tomrrow (Friday) morning - otherwise if i miss it i'll check the forums as soon as i get back next week.
cheers all
BRAD
Hey SmItLeR,
What I call the indicator stalk, is the assembly that sits in the steering column and pokes out that allows you to signal your intentions to turn left and right.
Am not sure if I need it for my problem, but worth a try if it is cheap enough.
El Bee
  • 10 months later...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
