Braking upgrade
hey all
did my first track day in my car ive just finished spraying. went really well and ran well all day with the exception of the braking.
First off they boiled there guts out by the end of each session. and the standard GTST stuff isnt up to scratch.
Obviously the easy way would be fit the GTR brembos. but they are pricey for what they are.
What are my other options? and what can i do to stop the boiling also?
Looking for all 4 corners
thanks
https://www.sau.com.au/forums/topic/471023-braking-upgrade/
1 minute ago, niZmO_Man said:
What pads, brake fluid in the car?
Look at ATTKD/D2/K-Sport/whatever kits.
That's what I'd use. Cheap, proven, good pad options.
In the meantime the GTST brakes aren't terrible so you might want to bleed it through with motul RBF600
https://www.sau.com.au/forums/topic/471023-braking-upgrade/#findComment-7837034
6 minutes ago, Adz2332 said:
ok sweet thanks guys ill look them up.
K-sport, i havent heard anything good about them, all be it in coilovers. are they decent with brakes?
Would rather go with the attkd version from just jap. That way you get a proper warranty if something isn't right with the kit. I dont think i've read anything negative about these. Some guys had issues with the ksport with rotors having too much run out from new.
  • Like 1
https://www.sau.com.au/forums/topic/471023-braking-upgrade/#findComment-7837040
Actually I think they are smaller, certainly they allow a lower offset wheel to fit by a few mm. Caliper size itself is not an issue, its about pad size, where the pad is on the disc, piston size, caliper stiffness. Ksport and all the other brands seem to use the same design/tooling and probably the same factory. I've used multiple sets over the years and the only real difference I've seen are the size, PCD and number of disc to hat bolts which mean the rotors are not all interchangeable.
WIth that AP set, they look like a good option, just make sure you can get replacement discs before you buy. They will use the same pads as the ATTKD/Ksport/D2 etc
https://www.sau.com.au/forums/topic/471023-braking-upgrade/#findComment-7837047
38 minutes ago, Dose Pipe Sutututu said:
You need adaptors, if you're after some decent braking power - go the Alpha Omega kit which uses the older Brembo from Evo 5-9 but uses the 350mm EvoX rotors.
its interesting that evo 7 8 9 all have the identical brembos. and can be had for a lot cheaper than gtr items
https://www.sau.com.au/forums/topic/471023-braking-upgrade/#findComment-7837066
careful with brake sets that look cheap; make sure it includes bolt on adaptors for your hub and chosen disc, brake lines, discs/rings (+ hats if 2 piece) and usable pads.
the only experience I've had personally with willwoods was really disappointing; Neil has a set of 4 spot ones on the radical and you should see the caliper flex when you put your foot on the pedal. Also poor pad availability for that caliper. But I guess that can't be representative of every caliper they make or they wouldn't be in business.
the alpha omega seem like a worthwhile approach too, but again include the cost of calipers, lines, decent pads etc when comparing.
finally, keep in mind brake size vs wheels you have or intend to buy. wheels bigger than 18 get expensive for semi slick tyres.
https://www.sau.com.au/forums/topic/471023-braking-upgrade/#findComment-7837073
You haven't said what fluid you are using, or how old it is. It's probably worth starting with a fluid flush, using a decent high-temp fluid (RBF600 as per Duncan's suggestion, or even better RBF660). The other worthwhile upgrade is ventilation - get as much air flowing through the brakes as you can.
The ATTKD brakes are good - we run the 8 pot / 355mm kit on a similar car & are very happy with it. We've got the stock rear brakes, and have no plans to change them - they are working fine with the 8 pot fronts. I wouldn't bother stuffing around with used Brembos. The airflow & fluid suggestions will still apply with a BBK.
How many laps are the sessions you're doing?
Have you considered entering a Supersprint at Mallala - the next one is on July 16th. Supp Regs are at Supp Regs - there should be at least 2 R33s running.
  • Like 1
https://www.sau.com.au/forums/topic/471023-braking-upgrade/#findComment-7837096
what class do you run?
https://www.sau.com.au/forums/topic/471023-braking-upgrade/#findComment-7837102
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
