I'm using those but as part of an upgrade kit. I also have 2 piece DBAs on the race car and 2 piece Ksport on the Stagea
Generally 2 piece rotors:
lighter due to alloy hat instead of all cast iron
dissipate heat better
cheaper to replace just the ring rather than whole thing
I haven't got them on the same car or tested back to back. But I am very happy with them. I would probably give them a go for a hard driven street car if they had a direct fit replacement like the link you had.
ATTKD are a Just Jap only brand AFAIK. But the Ksport, G4, D2 etc etc all seem to be the same or similar.
  • Like 1
  • 3 weeks later...
Im looking to replace my Sumitumos with Brembos because Im due for new everything front and rear.  I have a set of R33 GTR rear brembos.  Im curious if anyone knows FOR SURE if 350z Brembos with 350z rotors fit on the front of a R32 GTR.    I have heard the calipers and rotors off a 350z work together, just need to drill the holes to a fit the larger bolts, can anyone confirm this?
Thanks!
Thanks!
http://www.trak-life.com/diy-350z-brembo-brakes-conversion-nissan-skyline-r33-gts-t-gts-gts-4/
You're welcome :)
Google search 1st page.
  • Like 3
On 8/16/2017 at 6:31 AM, Dose Pipe Sutututu said:
lol, thanks man.. i even googled the hell out of it.
US edition of anything isn't a good thing lol.
Just remember you'll need the bolts from a R34 GT-t when you install them. The caliper bolts from a 350Z is too long. I think for you Trump lovers FRsport or Z1Motorsport have the correct bolts for sale.
  • Like 1
On 05/07/2017 at 10:45 AM, niZmO_Man said:
Something like this? http://www.empireperformance.com.au/home/138-mitsubishi-evolution-10-dimpled-and-slotted-front-brake-rotors.html
Also, there's a growing "trend" for the Commodore/GM Brembo calipers, not sure what the sizes are compared to Evo though.
has anyone got onto these guys lately? tried a few emails and calls and nothing back
41 minutes ago, Adz2332 said:
just looking to get out of it as cheap as i can for now
You can get these for 249 delivered
http://www.ebay.com.au/itm/DRILLED-SLOTTED-Mitsubishi-Lancer-Evo-10-2-0L-FRONT-Disc-brake-Rotors-RDA7117D-/400684560716?hash=item5d4aa9314c:g:z9IAAMXQ2dBSHdix
or plain like this for 171
http://www.ebay.com.au/itm/RDA-Front-Disc-Brake-Rotor-RDA7117-Mitsubishi-Evo-10-NEW-Genuine-OEM-Car-Part-/262917106965?hash=item3d3714ad15:g:lXkAAOSwbl5Zh98c
These where the first few that ebay results came up with for evo x
  • Like 1
Hey all,  anybody considered trying the CTS-V caliper swap that seems to be real popular with the S-chassis crowd in the US? Just taking a glance at eBay it seems tonnes cheaper to grab a set of 6-pots off one of those than try and go the 350z Brembo route. Plus the parts can be had new instead of used and (correct me if I'm wrong here) the disk size is also bigger. One company's offering adaptors for the S13/14 and 300ZX (literally just called CTS-V Swaps or something, first result on Google), got in contact with the guy who says the S13s should work no problem for the 33 GTSTs/R34 GTs. Been thinking of looking into it for my R34 GT so if anyone else has given it a shot would be interested to hear.
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
