Safe boost levels for -9 Equipped R34 GT-R
Hey guys,
I recently purchased a pair of GT2859R -9 turbos due to the stock ones having blade damage and needing a full rebuild. I was wondering since the new turbos provide more flow, what boost levels would be considered to be 'safe' on a completely stock RB26? I previously ran 1.00 bar on the stock turbos and the car seemed to run fine although I did notice the injector usage getting close and hitting 100% which makes me slightly concerned for the new turbos. Do you think the stock boost of 0.8 bar would be fine or possibly even less?
Cheers, Nick.
Edited by NAB 8
Changing format
Compressor map shows 22-psi is about max efficiency.
https://turbochargerspecs.blogspot.com.au/2011/03/garrett-gt28r-gt2859r-56-trim-310-hp.html
Approx 2.5 Pressure ratio on the graph.
HOWEVER, people argue that the limiting factor to the turbo's longevity is actually the turbine flow/heat and as you can see from the graph, the turbine starts to choke before the compressor does. Choke = heat, heat = premature wear etc.
So how hard you run them depends on the type of usage and your appetite for risk.
20psi should be fairly "safe" on both fronts, but 22-24psi squirts are not going to hurt a healthy turbo in a street application.
Other variables come into play here also, fuel type use? E85 has lower EGTs = happier turbo. Size of dumps and exhaust? Bigger = more flow, less backpressure and less work for the turbo. Etc etc.
We ran out of fuel pressure on the dyno at 373kw at 20psi on -9s in my car so this week we should see if it will happily hold 20-22psi. Keep in mind this is with N1 manifolds, 3" dumps into 3.5" exhaust, E85 and Kelford L182A cams (springs and head studs for insurance) with pods (proven to make more power at this boost on the dyno) and a Plazmaman intercooler.
To run 20psi+ on these turbos you will also need fuel pump, injectors, an ECU to make use of it all, and quite likely AFMs if you stick with those rather than going MAP (which would also mean needing a MAP sensor).
  • Like 2
Cheers for the quick reply Dan, I appreciate the effort too. Yeah I plan on getting injectors, ECU and a fuel pump later down the line but I will definitely keep this in mind :). In regards to running the -9 turbos on my current stock setup (stock injectors, pump etc), should running 0.8 bar be safe in terms of fitting within the stock injector's/pump's limits? even though it seems as if they were maxing out on the old stock turbos?
Remember PSI is just a pressure reading in the manifold and tells you nothing about the actual air flow being put out by the turbo/ingested by the engine.
For safety sake, you will want to put it in a dyno at a bare minimum and not be getting into boost until you do.
Make sure the AFRs are safe. As -9s are a step up in size compared to stock, they flow characteristics are quite different.
Usually, people do turbos with an ECU/injectors/pump etc as you can't make good use of the turbos otherwise.
Are the current turbos actually stuffed? Minor chips in blades is not a big eal at low boost and could allow you to get the other bits together and do it all at once properly.
Yeah the old ones are pretty far gone :/. I might just install the -9s then and keep the car off the road for a little longer until I can get injectors, ecu etc. Thank you for you help though :)
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
    • I've been quietly following this thread for ages, but this one got me. Since my ADHD diagnosis (and associated learnings and prescription) I'm way less inclined to wade into forum yarns when there are better things to do with my time, as half the time I'd end up in some kind of forum debate even if that wasn't my intention. I've not lost the ADHD "superpowers", just am a lot better at directing my hyperfocus into slightly more constructive things, but haven't stopped quietly lurking in here in my spare time.
    • Stripped the tank down and gave it a good scrub. It came up really good! Not sure if I'll just put it back in like that or give it a blackening treatment (such as Bowdens The Black Box). That might give it a matte look so might just run it as is.
    • @MBS206 Ha ha, yeah ADHD is a daily battle to not get drawn in to doing things you want to do that you know you shouldn't do!  Every single time I walk into my shed I end up doing something I started the day having zero intention of doing! I keep mentioning the 1 step forward, 3 steps back scenario and I'm tipping people that are blessed with ADHD (yes, blessed) are the worst at that!
    • We import a lot of cars from Japan. I'd say that approximately 20% of our traffic is imported JDM cars (mainly consumer cars like the Mazda Demio, Toyota Yaris, Honda Fit, Suzuki Swift, etc.). We also import a lot from the UK, but this has decreased after Brexit. Apart from the consumer vehicles, two of the larger, well-known dealerships frequently import iconic '80s/'90s JDM cars. I haven't heard of anyone importing from Australia, and they are not advertised (unlike Japanese ones), despite a lot of Maltese migrating to Australia in the '50s and '60s.
