S15 vs Evo 7-9 Track Car
18 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
S14-15 vs Evo 7-9 Track Car
Let the shit talk begin.
As a club level dedicated track car, which would you choose and why?
Evo is well regarded as one of the best track platforms around, but  Silvia's can hold their own as well.
For arguments sake, limit the budget to 40k purchase/build price as this is Club level events we're talking (sprints, enduro's etc, not door to door racing).
Silvia is lighter, less complexity in terms of drivetrain and electronics, cheaper most likely, and easier to work on at home maybe?
Evo comes factory with TS turbo, has proven AWD platform, stronger motor and gearbox (5spd).
Edited by ActionDan
https://www.sau.com.au/forums/topic/471038-s14-15-vs-evo-7-9-track-car/
Budget includes acquiring the car. To be fair yopu can get this for $25k or less and it would be fairly capable.
https://tracksales.com.au/browse/circuit/timeattack/2005-evo-9-track-day-car-554.html
Same power would see S15 with better power/weight. Is Evo grip enough to make up for that I wonder.
This is a skyline forum, so R33 GTST is my choice, has a gearbox and engine that doesn't break easily. Can get decent ones for under 10k, that leaves 30k+ for fasts. Can make just about any car quick with that budget. Probably wont be as fast as an evo with the same $ spent on it but will definitely be a lot of fun. Just a little biased lol :)
  • Like 1
Lol. That is one confused car. I reckon it's a 7 shell. No alloy roof.
It's funny this situation because 2 of my mates had an s14 and the other an s15.
The s14 guy went to a evo 7
The s15 guy went to a evo 8mr
Both beat their times at South cct with mild setups ie coilovers and tyres.
Mild or mildER?
Comparison doesn't mean much without knowing specs of each car. IF they were same tyres, same power and nothing else largely different, then cool. Thoguh you'd want to factor in cost to switch to the Evo vs gain in lap time.
If we're talking 300kw silvia's on semi's vs stock turbo evo's on good road tyres but still going faster, then damn :D
If I recall both silvias had the same setup (230kw)
GT2860
Injectors
Fuel pump
Exhaust (obviously lol)
(S14 had alloy radiator)
FMIC
Coilovers
Toyo r888/re55/a050/z221
Evo 7 (200kw)
Turbosmart wastegate actuator
Fuel pump
Exhaust
Coilovers
Toyo r888/a050/re55
Evo 8mr (230kw)
Fuel pump
Exhaust
Dunlop DZ03g/re55/RSRR
Silvias pushed coolant out the overflow nearly every track day.
This would have been my pick if i had the guts to sell my 34R and commit to more track time
Built motor, 5spd, front & rear diffs, mca golds, cage, can be registered.
http://www.my105.com/ListingDetails/id/18669/latest/1
https://www.carsales.com.au/private/details/_/SSE-AD-4636253?_ga=2.78987730.710373335.1498453303-698391425.1478472892
Edited by squareznboxez
  • Like 2
32 minutes ago, Hadouken said:
You wouldn't believe it but the "corolla" for the last 3 years has been wrx's.
price and availability.
The WRX version of the Evo is a Lancer Ralliart or wahtever.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
