S15 vs Evo 7-9 Track Car
18 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
S14-15 vs Evo 7-9 Track Car
Let the shit talk begin.
As a club level dedicated track car, which would you choose and why?
Evo is well regarded as one of the best track platforms around, but  Silvia's can hold their own as well.
For arguments sake, limit the budget to 40k purchase/build price as this is Club level events we're talking (sprints, enduro's etc, not door to door racing).
Silvia is lighter, less complexity in terms of drivetrain and electronics, cheaper most likely, and easier to work on at home maybe?
Evo comes factory with TS turbo, has proven AWD platform, stronger motor and gearbox (5spd).
Edited by ActionDan
https://www.sau.com.au/forums/topic/471038-s14-15-vs-evo-7-9-track-car/
Budget includes acquiring the car. To be fair yopu can get this for $25k or less and it would be fairly capable.
https://tracksales.com.au/browse/circuit/timeattack/2005-evo-9-track-day-car-554.html
Same power would see S15 with better power/weight. Is Evo grip enough to make up for that I wonder.
This is a skyline forum, so R33 GTST is my choice, has a gearbox and engine that doesn't break easily. Can get decent ones for under 10k, that leaves 30k+ for fasts. Can make just about any car quick with that budget. Probably wont be as fast as an evo with the same $ spent on it but will definitely be a lot of fun. Just a little biased lol :)
  • Like 1
Lol. That is one confused car. I reckon it's a 7 shell. No alloy roof.
It's funny this situation because 2 of my mates had an s14 and the other an s15.
The s14 guy went to a evo 7
The s15 guy went to a evo 8mr
Both beat their times at South cct with mild setups ie coilovers and tyres.
Mild or mildER?
Comparison doesn't mean much without knowing specs of each car. IF they were same tyres, same power and nothing else largely different, then cool. Thoguh you'd want to factor in cost to switch to the Evo vs gain in lap time.
If we're talking 300kw silvia's on semi's vs stock turbo evo's on good road tyres but still going faster, then damn :D
If I recall both silvias had the same setup (230kw)
GT2860
Injectors
Fuel pump
Exhaust (obviously lol)
(S14 had alloy radiator)
FMIC
Coilovers
Toyo r888/re55/a050/z221
Evo 7 (200kw)
Turbosmart wastegate actuator
Fuel pump
Exhaust
Coilovers
Toyo r888/a050/re55
Evo 8mr (230kw)
Fuel pump
Exhaust
Dunlop DZ03g/re55/RSRR
Silvias pushed coolant out the overflow nearly every track day.
This would have been my pick if i had the guts to sell my 34R and commit to more track time
Built motor, 5spd, front & rear diffs, mca golds, cage, can be registered.
http://www.my105.com/ListingDetails/id/18669/latest/1
https://www.carsales.com.au/private/details/_/SSE-AD-4636253?_ga=2.78987730.710373335.1498453303-698391425.1478472892
Edited by squareznboxez
  • Like 2
32 minutes ago, Hadouken said:
You wouldn't believe it but the "corolla" for the last 3 years has been wrx's.
price and availability.
The WRX version of the Evo is a Lancer Ralliart or wahtever.
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
    • Reasonably hard, although I haven't run it with the new Endless setup yet. The old brakes were F50's on 335mm rotors and the car did a 1:40.6 at Phillip Island which is a reasonable time, I'm seeing high 600s on the temperature paint. A guy I know ran the Endless fluid at WTAC without issues and he was doing 1:33's I think (Evo) with a 355/332 setup. I don't get out to the track as much as I'd like but we put the car on the hoist and spanner check every bolt and re-paint mark everything, bleed the brakes, change the fuel, check the coolant system and re-bleed blah blah blah before every event. Motorsport is expensive, RB's are expensive so a couple of hours before an event is time well spent. It's also a net time saving because if you can keep your RB from self destructing it saves you time in the long term!
    • Welcome Alice......hope you have a bit more luck from here on! What was done in the build?
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
