S15 vs Evo 7-9 Track Car
18 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Is that really enough grunt to be decently competitive though.
I know they use it well but you see most developed cars pushing high 200s on 98 at least.
I wouldn't have thought that would be a stretch?
I run low boost 230kw and continually place in the top 10 of my Interclub supersprint which consists of 60-80 cars.
And I'm not even using real r comps.
You say competitive but what are you going to compete in?
Wtac? Then yes. You're going to need at least 400kw
  • 1 month later...
I never wound up tracking my old 180sx, but my current evo 6 absolutely caned it in terms of grip, even on comfort spec bilsteins, OEM height and street alignment, nearly same tyre as well (re002/re003). I subsequently got MCA purples and RS3s, went to Wakefield for the first time ever (outside of PC sims I guess) and still shat out some fast times, despite decidedly lacklustre driving abilities. People say evos are basically cheating and I can see why... mostly jealousy. But at the same time they're not wrong.
HOWEVER, that being said, there's more to life than lap times. And there's always some arsehole at the track who's faster than you. The two cars are apples and oranges. The S chassis was the entry level option from Nissan and it admittedly lacks performance - but despite being the cut-price option it's still a pure sports car and drives as such. The Evo 4-6 was significantly more expensive in its day, but it's a basic bitch sedan turned rally homologation special, with a whole heap of compromise in terms of form (I think?), but greatly enhanced function -  vastly better engine response and head flow, faster steering rack, huge brakes and oil cooler from factory... and yet in some respects it still feels like I'm driving a riced out sedan. That feeling fades completely once I hit some curves at speed, because the handling really is sublime, the car rotates so easily and there's grip for days coming out of corners.
If you just want lap times for the lowest $ the choice is obvious tho
Edited by Skepticism
  • Like 3
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
