Don't want to spend to much maybe the 10k mark and would use a couple times a week and need the set up to be reliable and don't care about engineer cert. As I have never in the 8 years owning the car had cops look under the hood
https://www.sau.com.au/forums/topic/471039-slick/#findComment-7837359
Every engine you've listed will probably cost more than $10k to rebuild and install in an S15, think wiring, clutch, ecu, fabrication etc etc.
Why do you want an engine conversion, what are you doing with the car? A built SR20 will be both legal(enough) and will be a great match for the car.
https://www.sau.com.au/forums/topic/471039-slick/#findComment-7837406
I used to have a vl turbo and just loved the sound and the performance of it but the cops picked on me non stop so ended saleing it, the SR I want to keep aside as a original for one day. All the fabrication I will do my self as I'm pretty handy the only thing that I'm gonna have a problem with is the wiring but will sort it out, to have a 6 in it would be awesome the sound gives me goosebumps
https://www.sau.com.au/forums/topic/471039-slick/#findComment-7837407
RB25 now we're talking but one thing I don't know is can I use r33 k frame and g-box mount so I don't have to use after market mounts?? To save a little bit of cash there, thats all I'm stuck on If I'm going to do this...
https://www.sau.com.au/forums/topic/471039-slick/#findComment-7837576
Bullshit thats all you are stuck on !!! :D
https://www.sau.com.au/forums/topic/471039-slick/#findComment-7837582
    • Nope, but they are definitely one of the default choices. Well established.
    • Has anyone used > https://performancecoating.com.au/
    • Haha actually I did join back then under a different email address,  I couldn't re-activate my account so made a new one! I didn't post much anyway so not missing out on much. Amazing to see how the value of the cars and parts has changed over the years, also ACT section appears to be dead now.
    • Thanks... It's in pretty good condition overall, probably due to not being drifted/tuned however being a daily driver has taken its toll. Had 100k on the clock when I got it, up to 180k now. Unfortunately it's not 100% dent free, it's got a small dent on FLH side and broken indicator from where I hit a small kangaroo at high speed. If you look at closely at pic #5 you might spot the dodgy trailer light repair my old man and I rigged up as temporary repair! - It's still there due to a combo of needing the car as daily driver and then too lazy/busy to fix properly. I've a couple of other minor accidents accidents as well but nothing major. One required a new front bar and unfortunately the smash repairer ordered the normal gtst one and not the aero bar. Needed the car back asap so just went with it, regretted ever since.
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
