EOI at the moment as trying to get funds quickly for another setup I'm chasing. Basically take everything, long block hot and cold side all piping and intercooler ECU aswell as a nismo coppermix single plate clutch with less than 1000km on it.
ENGINE;
Unopened 33 GTR RB26 from an autech 260rs stagea. Good compression across all 6.
Splitfire Coilpacks
Fenix Alloy Radiator
Reimax billet oil pump gears
Tomei sump baffle
Full silicon water/heater hose kit
Turbosmart R34 BOV's
Rebuilt stock 33 GTR turbos with steel compressor wheels
RacePace Adjustable cam gears
RacePace 1000cc Injectors
Full Gates BioFuel hoses used from intank all the way through to the fuel rail
Oil Filter relocation kit with oil cooler WITH a thermostat
Major service completed approx 1000km ago. Timing belt, accessory belts, spark plugs,engine oil & filter, gearbox, diff and transfer case oils. Penrite 10 tenths 15w-50 engine oil (changed every 3000km due to being driven once every fortnight and recent E85 changover)
Also replaced the cam angle sensor on RacePace advice.
Electronics;
Apexi Power FC - Tuned by RacePace at 311awkw at 19 PSi (20 peak, 19 flat) on E85 ONLY
Apexi Power FC boost controller. (not installed)
Located south east melb.
Im an honest seller and I'm actually not too sure what all this is worth. My aim was to make it as reliable as I could at this power level with stock internals. Due to rules, I'm listing it at $10,000.
Throw me an offer.
Prefer text on zero424490one87
https://www.sau.com.au/forums/topic/471040-rb26-with-tasteful-bits/
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
