V36 Front Bar
Hi
Does anyone out there with an 07 V36 Sedan Type S know the height of the bezel/grille in the front bar, where fog lights would normally go.  Also is it removable?
I've tried looking at pictures and it seems small.  I want to fit 90mm lights down there and Im preparing in advance so I dont have a car to look at.
Pics for clarification.
Any help greatly appreciated.
https://www.sau.com.au/forums/topic/471046-v36-front-bar/
If you have the 350GT V36 (VQ35HR) then no, that grille is not removable. It is a false grille. Only the second batch of V36 have removable grille.
The first batch had their spotlights built into the headlights whereas the facelift versions had them installed at the bottom of the bumper.
  • Like 1
https://www.sau.com.au/forums/topic/471046-v36-front-bar/#findComment-7837865
On 6/30/2017 at 3:22 PM, petern said:
Just measured my one
22cm across the top left to bottom right
25cm from top left down to the bottom right
and 7cm height
You have me a little bewildered with your reply.
With my very crude drawing, is this what you mean?
https://www.sau.com.au/forums/topic/471046-v36-front-bar/#findComment-7838163
22cm length from top left corner to bottom right corner
7cm is highest point top to bottom
25cm length from top left corner running down to bottom right corner
https://www.sau.com.au/forums/topic/471046-v36-front-bar/#findComment-7838641
You mention top left corner to bottom right corner with two different measurements? How can that be?
https://www.sau.com.au/forums/topic/471046-v36-front-bar/#findComment-7838735
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
