V36 Front Bar
Hi
Does anyone out there with an 07 V36 Sedan Type S know the height of the bezel/grille in the front bar, where fog lights would normally go.  Also is it removable?
I've tried looking at pictures and it seems small.  I want to fit 90mm lights down there and Im preparing in advance so I dont have a car to look at.
Pics for clarification.
Any help greatly appreciated.
https://www.sau.com.au/forums/topic/471046-v36-front-bar/
If you have the 350GT V36 (VQ35HR) then no, that grille is not removable. It is a false grille. Only the second batch of V36 have removable grille.
The first batch had their spotlights built into the headlights whereas the facelift versions had them installed at the bottom of the bumper.
  • Like 1
https://www.sau.com.au/forums/topic/471046-v36-front-bar/#findComment-7837865
On 6/30/2017 at 3:22 PM, petern said:
Just measured my one
22cm across the top left to bottom right
25cm from top left down to the bottom right
and 7cm height
You have me a little bewildered with your reply.
With my very crude drawing, is this what you mean?
https://www.sau.com.au/forums/topic/471046-v36-front-bar/#findComment-7838163
22cm length from top left corner to bottom right corner
7cm is highest point top to bottom
25cm length from top left corner running down to bottom right corner
https://www.sau.com.au/forums/topic/471046-v36-front-bar/#findComment-7838641
You mention top left corner to bottom right corner with two different measurements? How can that be?
https://www.sau.com.au/forums/topic/471046-v36-front-bar/#findComment-7838735
    • I have a VALCON if anyone wants it, I have no idea why you'd want to have VVT specifically broken out of the ECU as opposed to running it off the FCON/whatever standalone you have.
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
    • Transplanting the vvt from a 25neo into an rb26?
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
