R33 GTR V spec - Series 2
up for sale is my series 2 v-spec R33 gtr
Reason for sale is change of circumstances with work,
it is unfortunate but this is the most logical thing to do
Power fc with hand controller
Greddy elec boost controller
Nismo cluster 188XXX
Nismo gear knob
Billion digital thermo fan controller
Blitz power id meter
Blitz hardpipe intakes
Top secret imports air box
Hks hardpipe intercooler kit
Greddy catch can
Copper radiator
Silicone radiator hoses
5zigen front pipes and cat back Also come with a hks diff back
Blitz kevlar strut brace
Excedy clutch and light weight flywheel
Tein coilovers
Nismo front caster arms
Nismo rear camber arms
Nismo control arms
Series 3 headlights (xenons)
Series 3 bumper and n1 ducts
Series 3 front lip (brand new)
Genuine n1 bonnet lip (bolted into bonnet)
Cusco bonnet pins
Nismo front indicators
Nismo side indicators
Varstoen 19" 9.5 +20 New
New internal locking nuts
Will come with x force dump pipes Running 19psi Turbos should be steel internals for that much boost but hard to say without pulling apart
I have attached invoices for massive overhaul and everything mechanically done by top secret at 174000.
text my phone, you'll get instant response and im happy to take more photos/videos if needed
I have knocked the price down to 30k. I am solid at this amount. do not bother low balling me
Bad points
small crease on left rear quarter and the bonnet pins on the paint work
air con idle hasn't been set up correctly in the power fc, stalls after a minute on idle
drivers mirror doesn't fold in with switch
wheels need to be re balanced. Slight vibration in steering at 100km. Only started when i put these wheels
I will consider swapping for a s15 with a proper cash adjustment. Needs to be adm, factory blue, sunroof, cloth seats and factory turbo/manual.
dont bother trying to swap me a piece of shit.
18813906_10155127806958598_8131715970978401311_n.jpg.d017407c9871968c699b354eee7a4c72.jpg
18882241_10155127806993598_5959707772870987782_n.jpg.57f125fd9be711c135f1f884a70441d8.jpg
18813975_10155127806998598_7276609814662012636_n.jpg.f838f37540cbbc405a6e70c1176a113b.jpg18920124_10155127807023598_2466761076929942583_n.jpg.2f1964f7fefe33a6bc24f2b31beef8e7.jpg
18951212_10155127806963598_7820529557385465062_n.jpg.cbf1c14c8f0ccad872970982ff9cb86a.jpg18950988_10155127807008598_7037655629875365230_n.jpg.3e2c6268f43c77ef26213e6831e32a59.jpg
18836073_10155127806943598_6182826413285197_n.jpg.7cbf2ea7c979eb664610a164b372aa51.jpg
18814214_10155127806948598_5572682142948224298_n.jpg.556d6bf43c40ebdf1b130734e909bf60.jpg
18836085_10155127807013598_4432651849789864521_n.jpg.57261ac57274bd8c62ce771ca8f91b14.jpg
cp4844216845634182258.jpg.40fd2f4caa54ac6bcded85a46d1ba5cd.jpgcp4925415846342795317.jpg.7fcc784796edb51699b1a51d50463506.jpgcp4899230858334177968.jpg.ba0b7f5eba51aa42265139a59213833e.jpg
https://www.sau.com.au/forums/topic/471049-r33-gtr-v-spec-series-2/
Last owner couldnt remember he said somewhere in sydney. Back when he purchased it and had all the service work done.
I checked numbers they're stock. However, Stock ceramic wouldn't last that many years on 19psi from what everyone has told me
1 minute ago, J180 said:
Does car have bonnet pins or not ?Is there holes in the bonnet ?Is that damage on rear left bottom quarter ?
Read the description
Yes theres a crease on the quarter and yes it has bonnet pins.
The rad support hasn't been modified
  • 4 weeks later...
    • Ha ha, ended up going it alone.  I just sent it (in a very nervous fashion).  Once I'd released the locks and it didn't automatically start spinning out of control i felt a bit more confident.   It made some loud sounds (cracking and creaking noises) when I first spun it which got the heart rate going again!  I couldn't bring myself to leave it tipped on the side.  I feel a bit more comfortable having back right side up while it sits there. I'd get angry with your last point but you're 100% correct! 😅 Even yesterday I managed to distract myself at numerous times to make a bracket to fit an LED flood light off the back of the house and fix my sons pushbike.  There were other little taks nibbling at my brain for the rest of the day too...
    • Probably one of the more nerve wracking experiences of my entire life! 😂😂 The balance (centre of gravity) is out still but in a direction that gives me comfort!   It's quite bottom heavy still meaning it takes a bit of muscle to rotate it.  The plus side of that is that it wants to to go back to upright.  Better that than wanting to go all stranded turtle on me!
    • hmmm that's not ideal. This is a pretty new engine right, will be interesting if your engine guy has any theories about causes
    • A universal ball joint removal c press kit is better money spent and will work for the Hicas ball joints.  Here's a 45$ CAD Example. ATPEAM Heavy Duty Ball Joint Press Kit with 4WD Adapters | Professional 4 in 1 Ball Joint Press Removal and Installation Tool for Cars and Trucks | Universal Ball Joint Tool with Storage Case, Ball Joint & Tie Rod Tools - Amazon Canada
    • True on both points
