Just ring VicRoads...
Their menu thing will put you staright through to the number plate division (providing you push thwe right numbers hehehe)
All you have to do is right down the number plates you wanna check and then real them off when the lady asks you, tick or cross the corresponding plates so you know which ones are available and which ones aren't.
You'll be fine. Give em a call.
https://www.sau.com.au/forums/topic/47105-vic-plates-check/#findComment-953662
i rang a few days back, it was easy. i only rang because i wanted to check if vic's can hav the number/letter anywhere they want, but she told me we cant. i swear i saw a car with the number in the middle and the word VIC above it.....
You probably saw someone with a Ham Radio plate
They range from VK3 AA to VK3 ZZZ...
https://www.sau.com.au/forums/topic/47105-vic-plates-check/#findComment-954409
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
