V35 sedan
Hi guys, have been searching through this vq section and finally getting some knowledge about these imports!
decided to make my own thread and put all my questions in one place!
bought myself an 02 v35 sedan 6 speed manual, has sunroof and factory bose audio. Always had a soft spot for the VQ range so I picked it up knowing there was clutch issues although having receipts of a clutch replacement
after reading through the common slave cyl / master cyl failures, jumped under and found it is leaking from the high pressure hose that connects to the slave. Some heat shield was missing so maybe overheated and cracked. Hoping this is an easy order and straight replace from justjap
Also read about the horror stories of the 8 speed auto cvt failures, and how people have been replacing them with 6 speed manuals, i sighed with relief having baught the 6 speed, but then noticed an 'extroid CVT' badge on my rear window, and now think maybe this car used to be the dreaded gt-8? As my centre console doesn't fit correctly/missing parts, and appears to be altered (especially around the gear stick.
the left foot rest (on left of clutch) also appears to be missing. Is this removed from an auto or did manuals also come with them?
I have posted pics but using iPhone so may have to scroll down.
Looking at replacing the 20' chromies as tread is MIA and I hate chrome. Thinking of 17/18s with a more aggressive offset and concave design. Would +12 be enough to have a lil poke? Current wheels don't show any ET. Will get a staggered set of 8' front and 10' at the rear. Guards have already been rolled
Drivers side window motor likes to wind itself down so will be replacing it from a stagea once i find a local wrecker.
Will also get some tint on the front to match factory rear window tint (guessing it will be like my x-trail which had 20% from factory on rear windows)
Does anyone know if the Nismo square twin tips are from factory? Doesn't make the best sound so may replace it, or just a complete new catback
its a shame about the radio freq. seek range and unusable sat nav but thinking about chasing up chris rogers (strangely enough one of my closest irl mate's name haha) for a wiring harness to connect aux and possibly connect a reverse camera like a few of you have done, although the step by step tutorial is 7 years old and all picture links are broken haha.
thx for listening to me ramble on, would love to hear some feedback!
- gaz
https://www.sau.com.au/forums/topic/471062-v35-sedan/
I think I saw this car on Carsales. I LOVE the sedan of the v35 and sometimes wish I had bought one instead of the coupe. I look forward to seeing what you do with this car and future mods. Im looking to have my Autobox replaced by a 6 speed, just havent found anyone who likes to work on these cars yet.
Good luck with it.
Cheers
https://www.sau.com.au/forums/topic/471062-v35-sedan/#findComment-7837699
check the build plate for the transmission code.  the CVT started with RE0R..... (I think)   the 6sp manual starts with RS6R...
But the centre console certainly looks like a bit of a auto/manual hybrid.
I also had the clutch hose spring a leak on my sedan, soon after working on the slave cylinder.  I just replaced it with one of these.
http://www.ebay.com.au/itm/HEL-Braided-CLUTCH-Line-kit-Nissan-Z33-350Z-OEM-Layout-/271391526298?hash=item3f30320d9a:m:mBDBMCQBNUHRjX8PIIkIcHA
I have coupe 18x8 rims on mine, which have a +30 offset, with 245/45 tyres, I had to roll the rear guards slightly to stop them rubbing.  If you want to go with +12 and 10in rims, you will need lots of camber to prevent rubbing.
Factory standard exhaust was not Nismo and was round tips.
Edited by sonicii
https://www.sau.com.au/forums/topic/471062-v35-sedan/#findComment-7837752
thx, ive ordered a z1 replacement braided clutch line but pretty much the same thing.
yeah it definately used to be an auto, nissan confirmed after checking the VIN
oh well, hopefully no dramas with this new gearbox. im going to try and source a replacement centre console from a wreckers. do you know if the sedan and coupe manual are the same?
anyone know if a vq25det turbo will bolt on to the vq35de fairly easily? not looking to make any crazy numbers but a lil boost without upgrading the internals possibly? 250kw or so?
https://www.sau.com.au/forums/topic/471062-v35-sedan/#findComment-7837754
  • 1 month later...
Has anyone modified cup holders in their v35's? Do stagea's come with any?
Curious to see if I can modify the old space for the tv tuner into some retractable cup holders lol
https://www.sau.com.au/forums/topic/471062-v35-sedan/#findComment-7842523
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
