Battery is leaking from the top
The battery in my 34 is leaking from the top where you put water in it from. Yesterday I had to take the horn fuse out from the engine bay and this caused the battery light to turn on and my turbo timer was showing 15.3v . At the time I didn't know it was the horn fuse but I drove my car like that for half an hour to get home then when I searched google I found out it was cause of the horn fuse. When I checked the battery today I saw that the tray had lots of water and a lot had leaked onto the railing and caused white deposits. I took it out and wiped it down. Car still has power to everything and battery doesn't seem weak but you u think I f**ked the battery by driving it for half an hour on 15.3v?l?
https://www.sau.com.au/forums/topic/471071-battery-is-leaking-from-the-top/
The battery should be able to handle that voltage. The question id be asking is, why is the battery leaking? Overfilled, or is it fubarred? I recently had one leak from where the top plate is joined to the body. Took it back as it was still under warranty and swapped it.
I made sure the water I put in the cells were about 2 inches from the top and made sure the caps are sealed. Had to use a screwdriver and hammer to loosen and tighten them because they were a weird design (two sideways triangles) and it ate into it a bit but don't think it's that. The water also came out black for some reason. The century battery didn't get hot after driving it on 15.3v and the battery hasnt swollen up or anything. But there were white deposits on the railing by the battery so that is almost guaranteed battery acid
Edited by IM-32-FK
12 minutes ago, junkie said:
alternator is overcharging and causing the acid to bubble up and leak out of the battery. check the voltage at the battery terminals while engine is running, anything 14.7 and above is a problem
its all good now i think its like 14.7 or slightly lower after i put the horn fuse back in and battery light turned off. Just wondering if the battery or alternator would go anyday now since i overloaded the battery and drove on 15.3 for half an hour.
Also whos bright idea was it at nissan to cause this battery overload problem by simply taking the horn fuse out?
Edited by IM-32-FK
1 hour ago, junkie said:
id say the battery would be fine, maybe shorted life somewhat but hard to say. if fairly new it will cope better, just make sure fluid level is sweet and keep an eye on the voltmeter
i got non xenon headlights now but i got stock xenon wiring on my car. So since they dont match up i had to do a temporary wiring so the lights turn on from the spotlight cable lol i got no fuses in for the headlights and it still turns on. Could that be short circuiting it?
also the battery is still slightly leaking from where the 6 cells are. i made sure they wernt overfilled and tightened the caps. WHAT GIVES? its a year old century battery
Edited by IM-32-FK
it wont short it if its wired up properly, i mean its already a closed circuit. but its a great fire hazard if it fails.
get it replaced under warranty while you can.
Edited by GH05T
    • Meh, At 60 years old, I have been doing dumb stuff for much longer than you mate, I am the true King And unfortunately I cannot be a maroon, as I am not brownish red As for not getting ITB's, the plenum intake will apparently show typical gains across the board and increase induction noise a bit, but, have all over less dort than ITB's Cost difference for the extra ITB dorts was significant though, the total parts for the plenum set up is "around" $2kAUD plus shipping, the ITB's were $4kAUD plus shipping, I was contemplating really hard about paying the extra $2k for all of the dorts, but weirdly, some form of common sense, from listening to the platform experts prevailed  As for the NA mod hate by some, I've had a few boosted cars, with all their inherent issues, I'm now looking at simplicity and legalities for a street car, maybe I'm just getting old, and I'm quite happy to spend some of the kids inheritance, 5kw at a time 🤣 And think of all the money I'll be saving on consumables that something with boost needs, like engines, gearboxes, diffs, clutches,  tilt trays... etc. etc. etc. 🤪
    • Haha.  I wouldn't say I am either but I've definitely been around it plenty.  I'm guessing you know the dial in is basically to make a handicap to level the playing field between racers.  The car with the slower dial in goes first and in theory if they run their dial in time and the faster car also does then they cross the finish time if they also have exactly the same reaction time - if you go faster than the dial in them you lose, but if you are too slow there's a good chance the other person will get to the finish line first. I'm normally supporting other cars but they were all pretty dialled and were egging me on to race as well, here's one of the cars I tune (Starlet) which ran within like 1 hundredth of its dial in through the competition: https://www.youtube.com/watch?v=inEBu-d9Gn4&t=69s
    • Where ever the fuel reg gets it reference is what I use to T into for map reference been a very long time so where it goes to plenum/runners I have no idea but never had issues.
    • What ecu? Same shop every time? Same ambient temperature? If timing is correct then pull plugs and see if lean or rich. Dyno can also read different if they have changed ramp rate or not set tacho/speed properly
    • I've never done dial in's just straight up, whatever that's called. I'm far from a drag (racing ) expert.
