Stages 2005 A/T
Hi Guys,
There is a wealth of knowledge here, which has been a godsend in helping me develop a better understanding of the RE5RO5A.
I ran the self diagnosis and found the fault codes for input clutch solenoid and turbine revolution sensor. I then drained the fluid, removed the pan and valve body.
Removed and tested solenoids, opened and checked TCM.
No faults so far.
Swapped input clutch solenoid and put it all back together. Replaced fluid and took it for a test drive.
Went well under light throttle but went into limp under heavy.
Ran self diagnosis with the same fault codes. Frustrated I went to a trans shop who ran their own diagnostics and quoted 3.5k for a new valve body.
I did some research and it looks like Hyundai and KIA both use the same jatco part numbers in their A5SR 1/2.
Can anybody share their knowledge or experience on swapping parts with these.
Cheers.
2005 Stages 250rx four
https://www.sau.com.au/forums/topic/471073-stages-2005-at/
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
    • Oh yeah, always always always turn over an engine by hand first.
    • So by that logic, an insanely expensive GTR for $200k+ is quite cheap, at 12% of Sydney's median house price compared to over 50% when a GTR was new...
    • Apologies... thought i had outlined it... Cheers for the response, I'll get a nipple sorted out for this.
    • lol thanks for the pics but some arrows might have helped for context. If you mean the bit I've badly traced in red, that is a PITA vacuum signal for the power steering pump, only R34 GTT was "lucky" enough to get it. Yes you will need a nipple of the same size somewhere in the intake between the air filter and the throttle or the power steering idle up will not work correctly
