Stages 2005 A/T
Hi Guys,
There is a wealth of knowledge here, which has been a godsend in helping me develop a better understanding of the RE5RO5A.
I ran the self diagnosis and found the fault codes for input clutch solenoid and turbine revolution sensor. I then drained the fluid, removed the pan and valve body.
Removed and tested solenoids, opened and checked TCM.
No faults so far.
Swapped input clutch solenoid and put it all back together. Replaced fluid and took it for a test drive.
Went well under light throttle but went into limp under heavy.
Ran self diagnosis with the same fault codes. Frustrated I went to a trans shop who ran their own diagnostics and quoted 3.5k for a new valve body.
I did some research and it looks like Hyundai and KIA both use the same jatco part numbers in their A5SR 1/2.
Can anybody share their knowledge or experience on swapping parts with these.
Cheers.
2005 Stages 250rx four
https://www.sau.com.au/forums/topic/471073-stages-2005-at/
    • Definitely the stroker kit. once you mention you have a RB28 everyone will assume you will flog them and hopefully won't start asking about support mods. Anyone will be too scared to race you, except maybe the RB30 boys
    • Just a quick update: I decided to go ahead with the de-cat for now. The exhaust shop inspected the catalytic converter and said it was in good condition. I took a look myself, and it does not appear broken nor clogged. After the de-cat, the car feels more responsive and smoother. The shop also reinstalled the exhaust temperature sensor into the de-cat pipe, and now the warning light no longer comes on, even when driving hard. The only thing that’s bugging me is the tinny, “can-like” sound the exhaust makes now (similar to having a hole in the muffler). The shop suggested that I might need to replace the muffler. I'll have to think on what to do next.
    • I want to start upgrading but don't have the budget to drop 15k at once, if i was to do one first which would be better and why?
    • Yuh. It is very rare for a single turbo to throw ceramic into the engine. Quite common on GTRs. As I posted above. Mine did destroy the O2 sensor on the way out though! Plastic compressor is fine with the temperature. It's not some flimsy PE/PET/PP thermoplastic. It's a thermoset resin with reinforcing material in it (a composite, as posted by @Lithium above). The compressor never sees much more than 100°C because it's never boosting very high. If you boost it high enough to make a lot of temperature, then the turbine will depart the scene and stop the party anyway.
    • From what I understand, it's a ceramic turbine and a plastic compressor (not sure how it doesn't melt then lol) I heard the series 2 r34 gtt has a metal turbine but I doubt that. @GTSBoy When you blew your standard neo turbo it didn't cause damage from memory just the turbine ended up in the cat?
