Stages 2005 A/T
Hi Guys,
There is a wealth of knowledge here, which has been a godsend in helping me develop a better understanding of the RE5RO5A.
I ran the self diagnosis and found the fault codes for input clutch solenoid and turbine revolution sensor. I then drained the fluid, removed the pan and valve body.
Removed and tested solenoids, opened and checked TCM.
No faults so far.
Swapped input clutch solenoid and put it all back together. Replaced fluid and took it for a test drive.
Went well under light throttle but went into limp under heavy.
Ran self diagnosis with the same fault codes. Frustrated I went to a trans shop who ran their own diagnostics and quoted 3.5k for a new valve body.
I did some research and it looks like Hyundai and KIA both use the same jatco part numbers in their A5SR 1/2.
Can anybody share their knowledge or experience on swapping parts with these.
Cheers.
2005 Stages 250rx four
https://www.sau.com.au/forums/topic/471074-stages-2005-at/
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
