Some one ask me what a RB20e looks like in a WD21
So. As some people have been following I started my "some one ask me what a TD27T looks like in a r32" Post
now to take a step back and go full retard.
two years ago I built a R33 on a D21 solid beam rear chassis. With a 20e. It went nuts. This time. Something different.
a WD21 terrano. Manual. 20ET with the body cut down to a ute. the aim is to finish by February 2018 and take it to the big river run in ashburton NZ.
so my question is. What turbo do I use!?
Heres a snap of my old one.
  • Like 2
I hate the run of the mill builds haha
iv done this one before but want to do I think a lot better this time around. And the 33 has been in my garage for like 6 weeks and I haven't even driven it lol
7 minutes ago, Duncan said:
hahaha people need to be careful what questions they ask you!
I wonder what a holden kingswood would look like with a 13b rotary in it?
I love this's hit haha
im not sure if you were pulling the piss... but. Factory kingswood rotor ;) Mazda roadpacer.
Lets put a 13b into a bus?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
