New memeber from the Caribbean
Hello everyone,
My name is Joe Risseeuw and I'm from the Caribbean.
an island called Curacao right next to Aruba.
I own a 1996 R33 GTST with currently a 25 Neo swap.
Spec list
Microtech LT12S @8K rpm
Garrett GT3582R .82 AR
Tial 38mm
ID1000s
Walbro 400 intank to surgetank, A1000 to rail
Spool Spline drive collar
Spool billet gears in N1 pump
Edited by JoeRisseeuw
  • Like 3
https://www.sau.com.au/forums/topic/471079-new-memeber-from-the-caribbean/
3 minutes ago, JoeRisseeuw said:
Anything you guys need to know about Neo swapping go ahead and ask. First hand experience. Wiring, coils, manifolds. I got you lol
With an attitude like this, you'll be in high demand here! :)
Welcome aboard. just into any discussions you think you can help on. Technical requests are always coming through.
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
