Damaged RB30 Block Repairs
Hi all,
I'm helping a friend rebuild a VL Calais. Long story short we bought the car for $2500 as a bunch of pieces and a rolling shell. Most of the car was there and we have managed to put it all back together. I should add that we are by no means mechanics, so please excuse my ignorance where it may appear.
We have managed to start the car and it does move under its own power after several months of rebuilding it, however, one of the exhaust manifold studs was bent and had been poorly re-tapped. Initially we believed this would not be an issue, however, it leaks radiator coolant from the re-tapped stud area (we just left the exhaust off the car for initial tests).
We have since learned that this cannot be repaired quite as simply as we had hoped and the block may need serious work to be any use to us. I believe that there may be coolant leaking into cylinder six. There is no water in the oil (we've checked twice). Obviously this is an issue and we are in the process of stripping and pulling the engine out for reconditioning. The coolant absolutely pours out of the exhaust port of cylinder six when the engine is running. I'd suggest it could empty the coolant from the car within 15 minutes if left to run.
My query here is, in the event that we pull the engine for re-condition and cylinder six is in good condition, is it going to be possible to repair the block of the engine?
We could simply have someone re-work the block and re-tap the stud, but does anyone know the effect that might have on the water path through the block? I'm concerned that if we attempt a repair we will re-direct the coolant path into the cylinder itself or some other area where we don't want coolant.
Can anyone offer their opinions on this matter or does anyone have experience with this type of problem? (Pictures to follow).
https://www.sau.com.au/forums/topic/471080-damaged-rb30-block-repairs/
well the good news is that the exhaust ports and their studs go into the head, not the block.....which means you probably have a perfectly good (and valuable) rb30 block.
the single cam rb30 head is probably worth about $3 including postage so you may be able to just swap it for another if you are trying to get it going cheaply.
  • Like 1
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
