Battery acid / paint damage / Negative cable oxidised
Obligitory I f***ed up and now i'm paying for it.
A year back i went interstate for about 3.5 months and left my car in a mates back yard with a tarp over it.
I'd left a lead acid battery connected thinking that i'd just jump start it when i got back.
Came back and i had a big star shape of rust under the bonnet above the battery and further surface rust below the battery area. Wonderful.
Fast forward a bit, change of address and saved some cash,  and firstly, can't find a competent person that can actually tackle this engine bay damage properly, and neutralise whatever the hell it is on the paintwork. I am assuming it is battery acid/vapor damage but i have no idea what happened.
I've paid a bloke 900$ in Dandenong (Vic) to crack at it and all his paint is just bubbling up and peeling off again. On their warranty card it says they don't cover rust and he doesn't want anything further to do with it particularly.
I've put a brand new lead acid from repco in there and the thing worked for about two weeks and now it won't hold a charge at all. Alternator is giving me 14.4 when i jump it, fortunately i had the alternator reconditioned only 20,000 km's ago.
I've noticed some oxidisation on that main negative lead thats soldered and screwed to the chassis but unsure if this can prevent a battery from charging.
At the end of the day, i think i've got f**ked battery and it has been leaking down its back all over my engine bay again, no idea why, it's 5 weeks old. I plan to replace
it with a dry battery if i can find one that fits.
I'll note that on this R34 the battery compartment was really tight and i pulled out a white tray that used to be under the battery. Is it neccesary or no? I know for example
my Falcon has its own plastic surround for cooling. This one On the R34 is just sitting on the chassis held with a clamp.
Questions i suppose, recommend a type of dry battery thats correct for 34 Gtt?
Can a bad negative connection prevent a battery from charging?
Why do these lead acid batteries keep freaking bubbling over ( amplified sound system in car too much strain?)
Know someone in vic that knows how to tackle rust/acid or an auto elec familiar with fault finding electrics in skylines.
Thanks for your time. I'm aware i f***ed up. cheers
If your tray is Ok and its just surface rust, I would go and buy some steel and brass brushes, plus some emery paper, and a brush for the 4" angle grinder and hit it hard.
Then I would buy some rust convertor/removal, probably in the gel format for your job and apply it and let it eat the rust away then hose off and dry immediately.
Get it nice and clean and dry!!!
I would then apply rust resistant paint undercoat and cover it. What you use for a topcoat is up to you.
While your at it, use the wire brushes, undo your earth strap and clean it up as well.  When re installing don't paint it etc, just leave it bare, except for a spray of CRC yellow contact or a smear of dielectric grease or Vaseline.
I personally wouldn't use a vented battery ever again.  Sealed batteries all the way IMO.
$900, you can do this for $200 and do a better job of it.
You probably need to check the voltage and amperage output of your alternator...could be that your regulator isn't working and the battery is being overcharged???
Damn man, how much battery acid leaked? I ran my battery on 15.3 volts for half an hour and it started to leak. How did the battery acid react to your metal in the engine bay? Below the batter tray mine is white and and the railing by the battery it is white now cause it lost the paint. If a simple sand down, followed by primer and paint enough to fix this issue? youre kinda scaring me now lol. Its only been a week since it happened
Thanks for the input.
Im32fk -  I don't know exactly what happened. Clearly the water in the batteries is nasty and if that drips down its caused the issues under, but i dont understand how its ended up on the bonnet above. The car was left under a tarp and it was very damp out, but the paintwork on this car has always been good. I don't think i'll ever know exactly what caused it.
I do not believe simply sanding it down is enough, to answer your question. The spray painter resprayed my bonnet and sanded back and bogged it 3x before it finally settled.
However I believe after sanding it back as suggested you massage some diluted Bi-Carb soda into the damage that might do the trick. Others might know better though. This is what i'll be trying to do.
Tridentt - thanks for your ideas. It is just surface at this point, just in an awkward spot, particularly on that rail near the engine. God damnit.
My Alternator is giving me a beautiful 14.3 volts, what i have found is that my spray painter has painted the rail and underneath the main negative leads clamp to the frame, so the clamp had a bad earth. I'm not experienced with DC systems but i believe squeezing 14.3 into the battery and having a bad return path probably f**ks them pretty quickly.
I'll sand back underneath the main negative lead clamp and put in a new battery.
Related - i'm having big troubles trying to source a replacement lead. Any ideas on where i can get one?
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
    • Yup but for me its the HR ! Cut my teeth on the old holden 6s in the day ! And here's me thinking in the day it was also the 300ZX and the Mitsubishi GT3000 ! All, as well had good lines, but always seemed to need finishing off, style wise.
