Skyline R33 series 1
Hey guys
So i have a series 1 R33 GTST. It had a blown motor in it so brought a series two long motor and used my series 1 turbo and intake. using series 1 wiring lume. i got it all fitted up on the weekend and guess what. no start. she cranks over fast but doesnt fire. so ive checked fuel. fuel is flowing freely and theres a bit of pressure behind it just after the fuel filter going into the rail. checked spark and i have spark at the spark plugs. checked injection pulse with a noide light and i have injection pulse. im kinda stuck at this point and not to sure what to attack next. im going to test fuel pressure tomorrow night just to make sure the pressure is right. i have tested it with 2 cas and no change. its just not making sense. i have fuel, i have spark, i have injection pulse. why wont she fire. any advice would be amazing. thanks guys
Edited by SkylineR33Lad
https://www.sau.com.au/forums/topic/471116-skyline-r33-series-1-no-start/
Hi,
I just got my skyline so I'm not particularly familiar with it yet but are all the sensors plugged in and proper? Maf, O2 etc?
A friend had his O2 sensor wires on his Rav4 chewed by his dog and had similar symptoms.
Thanks for the fast reply guys. yer smells like fuel if ive been cranking it for a bit. plugs were wet when i pulled them out on the weekend. got new plugs coming tomorrow.
ive gone over all my sensors and im 99 percent ive got them all hooked up.
ive even tryed to use some start ya bastard and had no hope. do you have to adjust your cas or does that bolt straight on. cause im thinking its timming but i replaced timming belt when engine was out and it was smack dead perfect
Update.
I found out that you adjust your cas for your timing since I just whacked it on I thought I had better give that a shot. I tried it in all angles as I would have to move it then go crank the key. Didn't make a difference. The weird thing is when I first crank the car. After it's been sitting it sounds like it fires straight away then just dies of and keeps on cranking over
When you first crank it. It sounds like it fires and then just sounds like it's turning over after that. I just compression tested all cylinders and they are all around 140:150. But when I was removing the plugs it came to my attention the spark plugs in cylinder 5 and 6 were dry. So I don't think I'm getting fuel into those cylinders. I have replaced all spark plugs. The car should still fire with 4 cylinders. I've all so checked over the link you posted . Yes I've checked everything on the list apart from timing. Can you check timing with out the car running. I have a timing light just need to make something up that can go into the coil. So I can put a ht lead for the pick up of the timing light
You really need the car running to check the timing.
I think you have already checked it but the CAS isnt a tooth out or something along those lines?
Is it just the standard ECU?
Be interesting to plug consult into it if so and see if there is an issue. My thinking is possibly AFM or water temp sensor perhaps (ECU thinks its -50 degrees or so)
Fuel pressure regulator hooked up correctly?
Im thinking that there may be a dud sensor. Double check all the connections (pull them out and check the pins) but you may have a sensor that is connected correctly but internally faulty
Wait hold up. Won't the car run with out the water temp sensor. I haven't got any of the cooling system hooked up. Not even the radiator. I'm pretty sure the water temp sensor is on the intake manifold and she's plugged in.
I'm pretty sure the cas can go on only one way. It's a standard ecu but the owner before me had a aftermarket ecu piggy backed off that one. Ive got another ecu coming tomorrow to plug it in and she if that makes a different. Also got another mass air flow sensor to try tomorrow. I'll check the fuel reg tomorrow but I don't think I really touched it so it still the same.
The car injects fuel differently depending on the water temp. So if your water temp is say 10 degrees, the car will run in a cold start mode and inject more fuel because it is colder
Like I said, this is all just guessing
I would strongly suggest hooking up the cooling system and correctly filling it to avoid any chance of the head or block warping or cracking
The issue you have described, we had a very similar experience with on an RB30. We found that the fuel pump wasn't working correctly and would not provide enough pressure in the system. Maybe double check that the fuel pressure is where is should be.
Ok guys so I've called in sick today to work. So I can try and figure this f**king car out. I pressure tested it from the filter as that was the only fitting that fitted my fuel pressure tester. I got 6 bar straight away. So I plugged in my mates ecu. Of his running 33. Still nothing! So I removed that ecu and put mine back in. I then changed the air flow sensor. Still nothing. I'm pretty sure that I'm not getting fuel to cylinder 5 and 6. I'm going to pull the plugs out on more time to conform that. I'm trying to post a video of it cranking over I can't seem to do it via iPhone. When I pump the throttle jut a little bit whilst cranking it sounds like it's firing. Any advice today would pretty amazing as I have taken the day of work
Okay so I pulled the fuel rail off so I can see if the injectors are blocked and clean them out. But when I got it out the injectors just don't look right to me. One of them have popped an o-ring half out. And one injector looks totally different to the rest.IMG_3442.thumb.jpg.cf4f7f52c85d93bded9d7284ccdd15c2.jpg
Still no start!!! Losing my mind here guys. Tried f**king everything. Don't know where to go from here. Please help. I tested all injectors when they were out by giving them a 12 volt feed. That all click when powered up. I'm lost.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
