Thanks Ben. I have put a timing light on it when it is cranking and it is in the middle of the timing marks I think there is six and it's in the middle. Can I pull the injectors out and then pull the cas out and turn the cas to make the injectors spray full just so I can see there spray pattern. I know they are all clicking when activated.
Yes you can
I think it is worth checking that the cam timing is correct before you go too much further. If that is correct, set the engine to TDC compression on number 1 cylinder and set the CAS so the spark is firing at number 1 plug. If it doesn't fire using Start Using Bastard, I don't think the problem is fuel related.
Okay guys so I pulled the fuel rail off again. And had my Mazda 3 running and stole a vacuum line of that to the fuel reg on the skyline. It turnt the cas and the injectors a clicking and there fuel getting to the rail but I don't think it's getting pass the regulator! Could this be the fault or at I missing something. There's only one vacuum line coming off the fuel reg! I've also got the return line off the fuel rail and there's no fuel coming out the return with the key on. But the pump is loud and I know there's 6 bar of pressure there.
It has already been suggested that you could have the fuel lines around the wrong way on the reg.
So swap them
  • Like 1
Hmmmmmm
You do not need to hook the reg up to vacuum for it to work
The vacuum/boost supply changes the pressure to suit what the car is doing. More boost = more fuel pressure. Without the Vac line doing anything you will have what is called base pressure
I think its already been suggested but just in case. Fuel pump line should go to filter then to rail then from regulator to fuel return
Okay guys I really was hoping not to have to post in here again but I need your help again. I am very embarrassed to admit but yes Ben you were right I had the fuel lines around the wrong way! Was spewing when it fire over straight away. But now onto the next problem. I have got it idling fine and sounds really nice but it is in limp mode after I drove it 500 metres up the road. I have checked all vaccum lines and Intercooler lines and they are all on. I did find a small vaccum line behind my glove box that wasn't hooked up to anything so I blocked it with a screw. I've triple checked every single plug and also tried the afm with the second one I have. I've also check for fault codes and I'm get 55 witch means everything is fine :/ Again sorry for the late response guys.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
