MY16 Subaru WRX (Swap Only)
Hi all, this maybe a long shot, I am looking to swap my MY16 WRX(Manual) for a clean R32 GTR, cash adjustment can be made either way.
Here is a little a bit about my car, i purchased the car brand new, currently has done just over 23k, always been garaged, only driven a couple hundred kms last 3 months, always do service either 3000kms / 3 months whichever come first. Tuned by Dan @ Rumble Shack in Wetherill Park (98ron: 203kw,403nm. e60: 226kw, 446nm ) ,body work is done by Mcgyer @ Auto Elements,  no money spared when comes to this car. One of a unique and tasteful new shape wrx around town. Please pm me if you have any question, thanks.
Sale Pirce:$42,000
Mods list:
Exterior
Opticoat Pro paint protection
Seibon CF bonnet
Custom made CF shroud
APR canards
CF front lip (cracked a little bit)
CF custom made rear diffuser
LED signal light
LED F1 style rear fog light
Roof spoiler wrapped(CF style)
Handing-
Billetworkz gear knob
Perrin short shifter + shifter stopper + Brass shift kit
Cusco Brake Cylinder Stopper
Cusco Front Struct Brace TYPE OS
MCA Blues
Volks Ray CE28 Bronze 18x9.5+40 wrapped with RE003
Engine
Cobb Accessport V3
Cobb BigSF Cold intake with airbox
Motion catch can x2
Invidia Q300 TBE (Heat wrapped Jpipe)
Mishimoto Top mount intercooler + charge pipe
Grimmespeed 3port boost solenoid
Turbosmart BPV
Cobb Flex Fuel Kit
Torquesolution egr + tgv delete
DW 300C Fuel pump
Edited by MightyV35
https://www.sau.com.au/forums/topic/471150-my16-subaru-wrx-swap-only/
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
