Loading up a track car
i have a 33gtst i use as my track car (pic below)
The car trailer i have makes it hard to load up as the ramps are to short and the front lip of my car hits when loading...
Its not as easy to put longer ramps on due to the design of the car trailer and how they are stored.
I dont want to make the car higher etc and im sick of putting my shit bumper on to load up
any ideas....? would finding a pair of 20s and chucking on some cheap tyres with a huge tyre profile lift it enough to get it on? finding 20s for a skyline could be tough that fit over evo brembos also
Any other ideas!?
https://www.sau.com.au/forums/topic/471151-loading-up-a-track-car/
A lot of people I've seen just remove the front bar in this situation, using Dzus fasteners or similar to make it quick and easy.
Otherwise, could try carrying blocks of wood around to help at the start of the ramp.
I feel like 20's with high profile will certainly have massive clearance/rubbing issues
I've got timber for my driveway. You have to reinforce it where it is lowest, and shave the ends so they sit flush against the two ends but they work well. And cost a grand total of $14 and one hour.
I should add we also used them for loading and unloading my car onto a trailer. Exactly as described above.
the easiest way to improve both the angle of the ground to ramps and ramps to bed of the trailer (where sometimes zorst scrapes) is to raise the rear of the tow car on caravan leveller/ramps or similar.  I've seen the same trick with a jack under the towball but I think that puts a hell of a lot of weight on a jack...
And if that's not enough go the blocks of wood suggested above at the start of the ramp, you can even have them flat on the ground as long as they are lower than the distance of splitter to ground on the car.
And if you can work out how to do it, long ramps are the real answer.  About twice what a normal trailer allows for is lovely.
  • Like 2
My car has a splitter on it and removing and re-attaching is a pain, I made 2 stage ramps with some handles from pine sleepers. They just sit on the trailer behind/in front of the car and are held on with tie downs.
Ghetto as but works and was cheap.
I could only find these 2 photos quickly and added one of the Silvia to show the splitter height. GTR clears it too.
The length was determined by how long needed to hit wheel before splitter edge hits timber.
I also have some of those little plastic Cusco ones that allow you to get just enough height to get a jack under it which is enough for people.
  • Like 1
I'd like to make a V2 that's lighter or I did consider running a drill through them to take core sections out but was worried about them cracking and splitting.
I am not a great builder/fabricator and have limited power tools so this was "easy" for me to do.
I've seen layers of ply screwerd together and then cut at one angle so there's no "steps" like mine. Would could be a better idea?
I have the same problem. I use the car ramp approach too. Back the rear of the truck onto the ramps to dip the trailer then a small plank that sits under the trailer ramps that the front wheels lift up on before the main ramp to help the nose clear.
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
