I'm going the Commodore route at the moment. Seems to be pretty straight forward but the plug for the TB is a bitch to find. I'm running a Plazmaman plenum with a custom adapter for the TB and a custom pedal mount (got Tilton brake and clutch so I needed to line then up anyway)
I'm going DBW for throttle blipping and smoother traction control, the Motec traction can be a bit harsh I find with ignition cut.
I am yet to fire it up so I don't have any real world experience for you, but I'm loving no idle control and throttle cable in the engine bay.
Edited by Komdotkom
https://www.sau.com.au/forums/topic/471162-dbw-options/#findComment-7839382
I'm running a 350z pedal and a LS2 throttle.
The 350z pedal bolts straight in so it's a no brainer and the plug is the same as a Toyota stepper motor (NZEFI sell them), the other good thing is the pedal bar is metal so you can change the angle etc by bending it to suit.
I think the LS2 throttle is a little too big and makes it a little touchy and hard to get the feeling linear, I'm looking at putting the 6-throttles back on and running a BMW M3 throttle motor to drive them.
  • Like 2
https://www.sau.com.au/forums/topic/471162-dbw-options/#findComment-7839453
