hi guys,
I don't want to start a brake pad review discussion - I've been reading the many pages of the Brake Pads User Ratings Guide - great info!
I replaced my front rotors ages ago and installed TRW/Lucas pads at the same time - and was/am very happy with the performance of the TRW pads on the front.
At the time the rears had plenty of pad left so I didn't change the rears
Time for a front and rear pad change now.
The car is mostly street driven with very occasional track use - I found the TRWs entirely capable for my needs.
I would be happy to install TRW pads all round, but I can't seem to find TRW pads for the rear of my R33 GTST.
TRW Part Number for front pads : GDB1269
I assume TRW make a rear pad, as I just watched a youtube vid of a rear brake pad change on an R33 4 door using TRW pads.
If anyone can assist with the part number for TRW brake pads for the rears on an R33 GTST, that would be greatly appreciated?
cheers,
Mike
Edited by mikel
  • 3 weeks later...
trying out Remsa pads, which are supposedly similar to TRW (I think the same company?) - good price $125 for a set (front and rear)
Changed the front pads this morning, but I have some new rear rotors on the way thanks to Johnny ( @Dose Pipe Sutututu ), so will change the rear pads at the same time.
Hats off to the Sumitomo/Nissan designers - the front entry design of the caliper is fantastic.
The fronts were incredibly easy to change - hopefully the rears will be as easy...
On Youtube videos I've watched, no-one seems to bother cracking the bleeder fitting to push the pistons back - I don't know why - the pistons go back much easier with less force with the bleeder cracked and a clear hose on the nipple into a waste bottle - I bleed the brakes afterwards anyway...
Also some YouTube videos show the caliper being removed - this is not necessary with the front entry design of the calipers! (unless your changing rotors also)
cheers
Mike
I've done my brakes a couple of times. To answer "I don't know why" people don't crack the bleeder, it's because 1. I'm lazy and didn't have some hose to bleed without a mess and 2. I wasn't gonna bleed the brakes if I didn't have to and 3. My brake fluid was a little low, so I just pushed in the pistons and voila! :4_joy:
18 hours ago, Hadouken said:
Just pull the cap off the resivoir then push piston back.
nice call, thanks - I'll do that for the rears - got my new rotors today and will fit up pads and rotors this week
fair enough - I change my pads so seldom, it's always way beyond the recommended life of the fluid, so I always put fresh fluid in and pump it through whenever I change pads.
Mike
was just surfing the DBA site - they recommend fluid is changed every 2 years - my fluid was much older than that :blink:
And it came out pretty yucky doing the front pads.
Unfortunately brake fluid absorbs moisture/water over time, which drastically reduces its boiling point, so hot brakes boils the fluid and brakes fade.
Put brand new pads in with old fluid and the fluid will boil on the track for sure - less likely on the street, but a spirited drive through the hills could mean major fade coming back down that last hill :down:
Fortunately IME, brakes don't fade instantly, you start to feel a spongy pedal and it's time to back off and let things cool down.
cheers
mike
  • 1 month later...
put the new rear rotors and pads on the car today
@bbenny  your thread:
was very helpful - especially the tips for the 2 M8 x 1.25 thread bolts to get the old rotors off, and the adjustment of the hand brake.
I went to the local hardware first to source the M8 bolts, but they couldn't confirm the thread was 1.25 - they had M8 bolts, but only the bolt length was quoted.
Fortunately there's a bolt shop not too far away open on a Saturday - when I asked them they said 1.25 thread is standard on M8 bolts - but I'm glad I checked.
The whole job went remarkably smoothly...
this worked fine - cheers @Hadouken - didn't need to crack the bleeder until bleed time at the end.
I recall a few decades ago changing the front rotors/pads on an XA Falcon, the Skyline is soooo much easier.
I seem to recall not being able to change the Falcon pads without removing the caliper - maybe it's possible - but you couldn't pop the pads out of the back side of the caliper...and replacing the front rotors on the Falcon meant mucking with wheel bearings! (the front rotor on an XA falcon contains the bearings).
It does bring a question to mind - when should you replace wheel bearings on Skylines?
cheers
Mike
cheers
Mike
Almost never.  They are really good bearings (both by design and quality) from the factory.  Especially at the rear, they can be completely shagged and you'd hardly notice.  To the extent that I spend a bit of time lately wondering if mine are stuffed and whether I should replace them!
  • Like 1
    • I'll tell her I put in a new air filter on it, which, it would have anyway with the ITB's In the end she isn't to fussed, she spends lots of money on hair, nails, make-up and all the other "required" beauty products that women use, plus I grease the wheels with shiny gifts and holidays wherever and whenever I can She once questioned my car spending "budget", but after itemising everything she spends on herself, and what I spend on her, and the fact that I don't care if she does or doesn't wear make-up and fancy pants perfume, or requires new outfits for every wedding, funeral or anything else she deems worthy, and I'm quite happy to go "real" camping, instead of staying in hotels or jaunts on cruise ships, she decided not to press the subject on how I spend funds, and has never asked "how much did that cost" again, so a win to me And how often can you say you really get a win with the fairer sex? She is a good woman, and in the big picture, I'm really lucky.....that she hasn't killed me yet
    • What will you do when the Minister of War and Finance says the intake noises are too loud?
    • Will the clear coat dissolve the ink tho?? I thought about clear vinyl tape too. Thinking what to do haha. The one I have now is cracked in 1 spot, otherwise mint. Plus the MINES one is much thicker plastic material so its not flimsy at all.
    • No. Go a different colour, and just trim it at an edge line. Even manufacturers do different panels different colours etc.
    • I see no real downsides to ITB's, apart from the initial cost of my drive in drive out lifestyle, the "upsides" is they sound cool and would add lots of smiles I am willing to pay to play for the extra smiles I've spent the morning googling and youtubing the BBR ITB's, a "little" extra power and throttle response, but alot more dort, and really, I'm only really in it for the dort Who knows, after all this money is spent I might even make 150kwatw....LOL
